Where is the Vehicle speed Sensor?
I am looking for where is this part located, the one that I thought was the Vehicle Speed Sensor was to the speedometer, the one I apparently need is the Transmission Output Sensor/Vehicle Speed Senor to the ECM, here is the part
please help, I have a 1998 transmission, t-45, and have NO CLUE where it goes.
the motor is a 2002 don't think that matters
When I did a search for a 98 Mustang GT, I got 2 sensors, one for Speedometer and one to ECM, your pic was to speedometer, the one with my pic is to the ECM, would that cause a failed code?
So, that is what I need to change to fix my code and pass inspection. P0500 was the code that failed inspection. Okay will get and change it and hope it passes, thanks again. Just would of never thought it would be that sensor cause my speed-o-meter works.
There are other problems that can affect the quality of the OSS signal, to properly check it you need the Ford IDS (Integrated Diagnostic System) or some other system that can access the VSS PID.
Here's what the shop manual says about P0500...
What PCM are you running, the '98 or the '02?
I ask because the '98 VSS produces 8 pulses per sensor shaft revolution (as it is gear driven the pulses per tranny output shaft revolution will be a function of the gear ratio).
However the '02 PCM will be expecting 12 pulses per transmission output shaft revolution unless it is reprogrammed--this could perhaps throw the P0500 DTC???
