Power steering resevoir question.
Old 03-15-2012, 10:37 AM
uberstang1
Chupacabra
uberstang1's Avatar
Default Power steering resevoir question.
Does anyone know why this is only 99-04 and not 96-04?
http://www.americanmuscle.com/moroso-pstank-9904.html
What is the difference between the tanks from 94-98 to 99-04? Will it work as is? Work with modofication? No go?
uberstang1 is offline
Old 03-16-2012, 08:30 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Don't know for sure about the '96-'98, but maybe the coil packs interfere with mounting the welded up reservoir???
'94 and '95 had the 302 pushrod engines with a different p/s pump (the reservoir was on the pump).
cliffyk is offline
Old 03-16-2012, 11:27 AM
uberstang1
Chupacabra
uberstang1's Avatar
Thats what i was thinking as well, but as loung as the outlet nipples are the same size im sure it wouldnt be hard to make work
Old 03-16-2012, 11:38 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
From what I have observed of your knowledge and accomplishments I'd gladly bet you can make it work...
cliffyk is offline
Old 03-16-2012, 11:46 AM
uberstang1
Chupacabra
uberstang1's Avatar
I hope so, sometimes the smallest easiest things always getcha in the end
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Power steering resevoir question.
