Whats needed to add cruise control? 98gt
Old 05-21-2012, 08:09 PM
whittdaddy
whittdaddy's Avatar
Default Whats needed to add cruise control? 98gt
I am new to the forum and would appreciate some help. I have a 1998 mustang gt that did not have cruise control on it so i am adding it. So far i have put the cruise control module on and the brake cut off switch and checked the fuse but still does not work. Does anyone know what i am missing. Thanks Jason
whittdaddy is offline
Old 05-22-2012, 09:29 PM
wolverine8490
wolverine8490's Avatar
Interesting, I never knew GT's didn't come with cruise. Even my 248a had it.... Is it a 5 speed or an auto?
wolverine8490 is offline
Old 05-23-2012, 07:53 AM
whittdaddy
whittdaddy's Avatar
Its a 5spd
Old 05-23-2012, 11:59 AM
BraMas
BraMas's Avatar
what are using to turn it on? did you put the buttons on the wheel like it has from the factory? Seems like becasue your car did not come with C/C the clock spring in the steering wheel would also be different?
BraMas is offline
Old 05-23-2012, 12:01 PM
zero2005
zero2005's Avatar
i'd check your wiring? how did you wire it up? i'll have to see if i can find a diagram for these.
zero2005 is offline
Old 05-23-2012, 12:15 PM
wolverine8490
If it is a 5 speed, there should be a connector at the clutch to kick off the cruise if the clutch is pushed in. It should plug in right next to the start safety switch. It is separate from the brake switch.
Also agree that the clock spring maybe being different.....
Old 05-23-2012, 01:13 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Here are the speed control wiring diagrams for the 2000 MY, your '98 should be the same as the last significant changes were in '96. In the 2003 MY the "redundant" brake pressure switch was eliminated.
switch, etc:
servo:
Note that the switch uses a low current +12V source (derived through the horn relay coil), ground, and three resistors switched to ground to control ON, OFF, SET/ACCEL, COAST and RESUME.
When I installed my aftermarket wheel I wired three momentary switches like this:
I installed the switches into a custom polished alloy plate in the shifter surround:
cliffyk is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
defarmer
08-13-2015 06:40 AM
Quick Reply: Whats needed to add cruise control? 98gt
