4.6 rebuild kits
4.6 rebuild kits
At first I was planning on just doing an engine swap but I changed my mind so now I was looking at rebuild kits and stumbled across this one from summit racing.
http://www.summitracing.com/parts/FEM-CSMHP798-322/
I just wanted to get feedback to see if it's worth it or if there is something more better I can get.
That kit would work great, but that kit is for a crank that has been or is going to need grinding. Do your self a favor and take your crank, rods and block to a good machine shop and let them take a look at the crank and rods. They will let you know what size bearings to go with. OH and make sure that you get the same dish piston so you dont end up with clearance issues. Good luck with the rebuild.
I prefer to assemble my own rebuild components based on the design objective. The Summit kit is a great place to start, but you will still need head bolts, main bolts, maybe a high volume oil pump, etc. If you don't want to mess with ordering parts, consider letting your machinist put together a kit for you tailored to your rebuild plans. Summit has great prices on parts. You can also get great prices on Ford brand parts from Tousley Ford. These guys really know their stuff too.
http://www.tousleyfordparts.com/
if its in your budget id just go with a built shortblock from mmr
http://www.modularmustangracing.com/
Talk to the guy at excessiveracing.com He is building me a long block complete and ready to go for the same price rebuilding my engine with parts from MMR would have cost. Once you start the tear down you realize all the extras you need. Oil pump, balancing the new rotating assembly etc. Plus the new engine comes is coming with new ported heads and cams.
I checked out there shortblocks and they are rated for 600hp which is about the same price as mmr. I'm working on a budget myself tho.
Excessiveracing.com
Race Prepped and Fully Machined Season 4.6L Romeo Block
Double Torque Plate Honed, Zero Decked and Align Honed
6 Bolt Cast Crankshaft, 3 Stage Micro Polished
Forged I-Beam Connecting Rods with ARP Wave-Lock Bolts
Diamond Forged Pistons
2V, 3V or 4V Reliefs
2618 Alloy Great for Boost and Nitrous
Diamond Pro Select Steel Nitrided Top Rings
Napier Cut 2nd Rings for Oil Control
Clevite 77 P-Series Main and Rod Bearings
New Main Bolts and New Side Bolts
New Brass Freeze Plugs and New Oil Gallery Plugs
Block Painted Any color you want
Internal Balanced, Blueprinted and Professionally Assembled
Add Moly Skirt Coating - $125.00
Add Full Length Windage Tray - $100.00
Upgrade to Manley H-Beam Connecting Rods - $300.00
Shipping Anywhere to the
lower 48 States just $250.00
MMR - http://www.modularmustangracing.com/
MMR 4.6 Street Mod 600 (up to 600 RWHP) 2V, 3V or 4V
The perfect replacement for your forced induction or NOS GT
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New Ford Racing Cast Iron Crankshaft rated up to 600HP (8 bolt or 6 bolt)
*New 4340 5.933 MMR (Modular Mustang Racing) I-beam Rods, these rods are
shotpeened, magnafluxed and weight matched
*New Forged Manley lightweight pistons
*Total Seal file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
* Clevite Rod and Main bearings
*Complete Pro Assembly and Balancing for the smoothest, highest revving
shortblock available, Pre-Lubricated with Royal Purple Assembly Lube and spin tested. Lastly 3 technicians sign off on your new engine prior to packaging and crating.
Shortblock Options:
Use Customer Supplied crankshaft SUBTRACT $200
Use Customer supplied Block - call for details and pricing subtraction
Coated Pistons (ceramic dome/teflon skirt) $399.99
Brand New Current production Aluminum Block +$999
NEW Ford Racing BOSS 302 Cast iron Block $999.99 (increases engine size to 5.0)
Upgrade to MMR block side bolts (recommended for 500+ HP) +$49.99 (free installation)
ARP Mainstuds (recommended for 600+HP) +189.99 (free installation)
MMR Street/Racing Oil Pump (highly recommended) + $159.99 (free installation)
MMR Performance water pump $79.99
MMR/Felpro Extreme Duty Headgaskets + $169.99
ARP Headstuds +$289.99
Upgrade to ARP 2000 Rod Bolts + $99.99 (free installation)
MMR windage tray and hardware kit (+15HP) + 129.99
Shown below with optional aluminum block
Extended Warranty +$300 (extends warranty to 18 months total and includes shipping to and from MMR)
If ordering online please state options requested in the notes section, we will add them before processing your order.
Which one is the best buy?
I went with excessive for a few reasons. You don't have to send them any parts. I needed heads and wanted a set of cams and they built me ported heads with cams and assembled the long block for about 500 more than a new set of stock heads would have cost with the short block. Jordan (the owner) was great to deal with and didn't try selling me more motor than I needed and has been super helpful with advice the whole time. Also the MMR engine uses Manley pistons and they don't come with valve reliefs so MMR cuts them into the piston top leaving only .070 worth of metal in those areas. Excessive uses custom cut Diamond pistons for the same price and they manufacture the reliefs into them. I'm spending a bit over 5 for everything. Not sure what your budget is but to rebuild my old engine with just buying the rotating assembly and putting it together myself I was at 4700 with new stock heads.
