rims and brakes - question
Old 10-02-2012, 03:20 PM
dthomas
dthomas's Avatar
Default rims and brakes - question
I am looking to upgrade the rear tires to 10.5 currently there are 17" rims, they have the Bullitt replica wheels. My plan is to have a Supercharger put on the car. Suggestions on brakes to use w/ 17 - 18 ' rims ? I have seen that the replicas run into a housing or clearance problem w/ Brembo HD Brakes..Any and all suggestions are helpful...
2nd- Besides the Axle upgrade/ and 31 spin/ any suggetions on the Rims handling any kind of torque/and power with an SC?
dthomas is offline
Old 10-02-2012, 03:29 PM
Shampue
Shampue's Avatar
The proper brake lines, pads & fluid will be more than enough stopping power. If you want to go with larger diameter brakes, its more than likely a cosmetic reason (like me) There is a sticky/tech article from Jazzer floating around here that goes into great detail about brakes.
Edit: Found Jazzers write up
Instead of screwing around with clearance concerns I went with cobra front brake calipers (along with Hawk HPS pads and DOT 4 fluid)
Shampue is offline
Tivo304
08-28-2023 12:19 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
DoctorScary
09-09-2015 07:53 AM
Quick Reply: rims and brakes - question
