mach 460 amp power supply?
Old 11-24-2012, 01:58 PM
jeffjanofski
jeffjanofski's Avatar
Default mach 460 amp power supply?
I have a 1999 mustang V6 (non-mach sound). I bought a used mach 460 speaker box with the two amps out of a 2000 GT (along with the radio & CD player). Should the wire harness connect directly into the stock setup on my mustang or will I need additional wiring (between the radio &/or the amps). If it plugs in, where on my existing main wires does it connect because I can't find the connection location?
I see there are two plug ins for the amps (on both ends) and the two speaker connections. Where do the other two connectors connect? (additional external cd changer and mach 1000 system equipment?). Seems to me the amps need another power supply.
jeffjanofski is offline
jwog666
12-27-2021 08:09 PM
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
jrrhd73must
10-02-2015 09:17 PM
Sixer4Life
09-29-2015 07:03 PM
1BAD3V
Indiana Regional Section
09-26-2015 09:03 AM
Quick Reply: mach 460 amp power supply?
