Best riding shocks/struts for lowered 02 gt vert?
Old 01-16-2013, 04:29 PM
luke1333
luke1333's Avatar
bilstiens ordered....
luke1333 is offline
Old 01-16-2013, 04:37 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I thought you wanted a "better riding car"?
cliffyk is offline
Old 01-16-2013, 08:39 PM
luke1333
luke1333's Avatar
I do and better handling car. the stuff is due for an upgrade in that department. the ride is poor right now. car can't keep up with the spring rate of the lowering springs. the bilsteins won't make it ride and handle?
luke1333 is offline
Old 01-17-2013, 06:14 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Though "good ride" is a very subjective thing, part and parcel of using lowering springs is that you also reduce suspension travel; meaning that those springs must have a higher compression rate and that the shock absorbers (struts on our modified MacPherson front-ends) must be stiffer so as to better control jounce and rebound. This creates a more harsh "ride", and there is no way around that.
It is why Ford makes Mustangs look like monster trucks from the factory; the general motoring public are willing to trade off decent handling for a cushy ride. The high stance and long suspension travel allows for use of less stiff shocks = "better ride".
In my experience Bilsteins are excellent shock absorbers, I ran them on my lowered Miatas--which my father would not ride in because he has had two spinal fusions and can only move because of cortisone injections--"rides like a buckboard" he would say, while I thought it was great and stuck to the road as though it was on rails.
So at the bottom line it all depends on your definition of "good ride". My car, lowered 1-1/2" and running the Gabriel Ultras, is rather jarring at high speeds over sharp bumps (like construction zone pavement changes) with Bilsteins it would really wake you up...
cliffyk is offline
Old 01-17-2013, 03:05 PM
luke1333
luke1333's Avatar
so you saying bilsteins are worse then gabriel ultras or better? and i get the longer the shock/strut is allows it to be more forgiving. Bilstiens can keep up better with lowered springs instead of stock struts/shocks.
luke1333 is offline
Old 01-17-2013, 05:34 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Define "worse". They will provide a more harsh ride then the Gabriel Ultras--whether that is better or worse is up to you.
I don't know what you mean by "the longer the shock/strut is allows it to be more forgiving", I never said anything about the length of the shocks/struts?
"Bilstiens can keep up better with lowered springs instead of stock struts/shocks", so can the Gabriels. The Bilsteins will handle very rough roads better than the Gabriels, at the expense of a more harsh ride on regular run-of-the-mill roadways...
cliffyk is offline
Old 01-17-2013, 09:38 PM
bullitt 736
bullitt 736's Avatar
You made the correct choice.
bullitt 736 is offline
Old 01-22-2013, 05:07 PM
luke1333
luke1333's Avatar
by getting bilstiens?
also got steeda x2 ball joints and bumpsteer in today and also got some j&m lca in that are ride height adjustable. uprshard is probably going to kill me LOL
luke1333 is offline
Old 01-22-2013, 07:00 PM
bullitt 736
Bilsteins are excellent. You really don't need the Steeda ball joints and bump steer kit though.
You should read thru the instructions on how to set the bump steer kit on MM's website before proceeding.
Old 01-22-2013, 07:40 PM
luke1333
luke1333's Avatar
while I agree I probably don't need them at my low mileage I do have a couple control arm bushings bad or going bad so the control arms are going to be out anyways so might as well press in new ball joints and match that up with a bump steer. agree?
& been reading lots of instructions. you ever put them on?
luke1333 is offline
Quick Reply: Best riding shocks/struts for lowered 02 gt vert?
