driving a 5 speed
Old 03-06-2013, 06:48 PM
  #21
SXGT
SXGT's Avatar
Originally Posted by 1slow67
I don't think so
everything i have ever seen or read or heard has suggested to me that manual transmissions get better MPG than Automatics which are heavier, hotter and lose a greater % power.
but my 1997 had a 2.73 rear end. this new one has a 3.27 ? something like that? still,. 12MPG with mostly highway miles is unacceptable, even if i had 3.73s and 400hp
http://www.consumerreports.org/cro/2...sion/index.htm
SXGT is offline
Old 03-06-2013, 07:51 PM
  #22
Fryguy22
Fryguy22's Avatar
I agree. You should be getting way better mpg. Try basic maintenance. How's the air filter look? Has the fuel filter ever been replaced? Spark plugs? Clean your injectors. A tuner might help as well.
Fryguy22 is offline
Old 03-06-2013, 08:05 PM
  #23
SXGT
SXGT's Avatar
ive not had the car long and weather has been a factor in me not getting anything more than an oil change done. it has a K&N filter, do i need special oil to clean it with?
SXGT is offline
Old 03-06-2013, 08:26 PM
  #24
Stevo86
Stevo86's Avatar
I am going to see if my gas gauge is faulty but seeing what numbers show up on my next fill up. Last time I got gas it was from less than a 1/4 tank and the gas pump shut off at 8 gallons.
Someone may have said this, I didn't read far enough. But you have a 15 gallon fuel tank. If it only took 8 gallons from less than a 1/4 odds are your sending unit is reading improperly.
Try this. Fill up, drive 40 miles. Fill up again, you should have burnt about 2 gallons of fuel. That will give you a good idea whether or not this thing is really sucking down fuel like it's cool.
Stevo86 is offline
Old 03-06-2013, 09:18 PM
  #25
FlamingoGT
FlamingoGT's Avatar
Mileage on mine sucks. I get as good with my truck, and it is a heavy 4x4. Back in the day I had a 90 GT 5.0 auto, and it got a lot better than my 04.
But I do agree with what Stevo said above... 8 gals should be just shy of 1/2. Try filling it up, driving a set number of miles, then fill up again... don't go guessing until you fill it back up as that should give you a better idea of how much gas you really did use.
FlamingoGT is offline
Old 03-06-2013, 09:34 PM
  #26
BraMas
BraMas's Avatar
Originally Posted by Dooney
they will definitely affect performance. They are constantly sending signals to the ecu to tell it what it should be doing with the fuel trims. I would check your air to fuel ratio and see how far off it is from stoichiometric (14.7:1)
No they dont!!!!!!!!!!!!!They monitor what the cats are doing they do not adjust the ECM in anyway.
BraMas is offline
Old 03-07-2013, 12:28 AM
  #27
SXGT
SXGT's Avatar
i hope so!
SXGT is offline
Old 03-07-2013, 12:42 AM
  #28
Risky guy
Risky guy's Avatar
+1
Have you cleaned the throttle body can get gummed up & really affect mileage.
When I had my gt , by 30k tb was covered in oil and some gunk.
Removed the by cleaned it up , car drove like a million bucks.
Gas mileage improved & no idle issues.
Risky guy is offline
Old 03-07-2013, 10:50 AM
  #29
SXGT
SXGT's Avatar
time to break out the sea foam!
SXGT is offline
Old 03-07-2013, 04:35 PM
  #30
SXGT
SXGT's Avatar
da *** ?
its some ****ty adapter. . .
ALSO, turns out all my tires were under 20psi.... one was even 12. So i aired them all up to ~35 that should help a lot on MPG.
SXGT is offline
Quick Reply: driving a 5 speed
