rearend spring advice
so ive replaced rearend springs, with new stock ones. got new konis, all around. now, ive decided that my *** end is a little to spongy. would stiffer springs, tighten me up? maybe , just some spacers. i dont know. the front end seems to perform, just right. its all new up there also. any suggestions? thank ya !
thats not stock. hmm. its possible they are really old and just worn out. say if they got put on in 2001...thats 12 years of use on an aftermarket part.
When you press your body weight down on the back of the car does its bounce like a water bed or stay stiff.
Ebach has some realllllly affordable spring you can check out.
http://www.americanmuscle.com/94-98-...g-springs.html
http://www.uprproducts.com/mustang-e...prings-v8.html
The four link rear end setup is a pour design on cornering performance. So a bad design plus a decade of wear on parts will result in pour performance. The stiffer springs will help but if all the bushings are shot, that axle will wiggle like a worm still.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
