Front control arm bushings
Old 05-19-2013, 12:17 PM
GoldieStarr
GoldieStarr's Avatar
Default Front control arm bushings
I searched around but all I'm finding is info on the rear control arms. I'm replacing the worn out bushings on my gf's 1998 gt. My question is how many bushings do I need to get for the front control arms? Are there lower and upper? I went to ford to price them and the guy said they don't sell the front upper arm bushings. I would have to order the whole upper arm.
I want to use the OE bushings. I am ordering the bushings from rockauto.
Thanks
GoldieStarr is offline
Old 05-19-2013, 05:17 PM
Seabee1993
Seabee1993's Avatar
Have you even taken the wheel off to see what you're needing to replace?
There is no upper control arm, and the Ford guy should be punched in the face for not giving it to you straight.
Here is an article that will tell you everything you need to know about the entire suspension system from 79-04. Educate yourself!
http://www.miracerros.com/mustang/t_suspension.htm
Seabee1993 is offline
Old 05-19-2013, 06:12 PM
GoldieStarr
yes I have taken the wheel off numerous times as well as lift the entire car. The car is all original from 1998. Everything rubber is bad.
Thanks for the link
guitarman376
10-11-2015 01:47 AM
Ghost_Conscience
09-23-2015 02:17 PM
09-16-2015 07:53 PM
FivePointToTheOh
09-14-2015 03:35 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Front control arm bushings
