air conditioning problem
Old 06-25-2013, 08:31 AM
egossenberger
egossenberger's Avatar
Default air conditioning problem
I was having problems with my air conditioning not blowing cold, so I went to refill my refrigerant, but when i went to read the gauge after 3 minutes of running, the compressor would come on, the gauge would rise to approximately 45 PSI, then the compressor would turn off and the pressure would drop immediately. Is the system overcharged? Or is there some other problem?
egossenberger is offline
Old 06-25-2013, 04:13 PM
go-part
Former Sponsor
go-part's Avatar
What side was the gauge on? High or low?
http://www.aa1car.com/library/ac98.htm
go-part is offline
Old 06-25-2013, 04:19 PM
egossenberger
it was the low pressure valve
Old 06-25-2013, 07:14 PM
AzPete
AzPete's Avatar
If the system is to low, there is a low pressure switch to shut down the compressor. Adding coolant will bring it up so the switch stays on. Just follow the instructions on the can and it should work.
AzPete is offline
Old 06-26-2013, 06:26 AM
Stevo86
Stevo86's Avatar
If the system is too low, find the leak before you refill it. That stuff doesn't wear out or anything. If it isn't charged it's leaking.
Stevo86 is offline
Old 06-26-2013, 10:50 AM
The02GT
The02GT's Avatar
Only read the gauge while the compressor is ON and your finger is off the trigger to fill the system, dont read the gauge with the compressor off. Once the compressor stops kicking on and off its pretty much full
The02GT is offline
djbigskrilla
09-20-2022 01:04 AM
67STANGX2
12-28-2015 12:17 PM
SYNY5TER
09-02-2015 01:35 AM
DrunknRuckus
08-23-2015 10:05 AM
Quick Reply: air conditioning problem
