Why don't these intake gaskets appear anywhere online?
Old 07-01-2013, 03:52 AM
Doublevision
Doublevision's Avatar
Default Why don't these intake gaskets appear anywhere online?
I was looking over the intake gaskets that came in my kit and they are not the same. I looked at the alternative kit to this one and they are not the same either. It seems as though not one auction I searched came up with these gaskets.
The biggest difference is that one hole is not shaped like the other three. Secondly the gaskets are replaced individually instead of on a strip.
Why are these gasket seals not available when searching intake gasket 4.6?
Doublevision is offline
Old 07-01-2013, 06:07 AM
Sonic Mustang
Banned
Sonic Mustang's Avatar
It seems like you're only looking on E-bay and you might not be usiing the same key words as the sellers.
Beyond that, nobody here can answer why nobody on E-bay is selling those gaskets. You'll have to ask them.
You should of asked, "Where can I get the correct intake gaskets?"
99-04 and 96-98 gaskets:
http://www.latemodelrestoration.com/...skets-Hardware
Do you have the original intake? Is it aftermarket?
Better yet, call and ask.
Sonic Mustang is offline
Old 07-01-2013, 09:14 AM
MaxxRPM
MaxxRPM's Avatar
Thats a Dorman intake and you have to use Dorman gaskets....
You can find them on Autozone and Advance Auto websites.
MaxxRPM is offline
Old 07-01-2013, 10:44 AM
Doublevision
Completely wrong, but thanks for trying.
Old 07-01-2013, 10:45 AM
Doublevision
Thank you, I'll head down there and see if they can help . I was able to FINALLY find the right one's looking up what you said.
http://www.stockwiseauto.com/product...ucts_id/248520
Thanks a million.
Old 07-02-2013, 01:33 AM
Sonic Mustang
Banned
Except for asking if you have an aftermarket intake. And showing you whast the two variations of stock gaskets look like. And pointing out you asked the wrong question in the first place.
Yeah, completely wrong.
Old 07-02-2013, 02:24 AM
Doublevision
Lotta butthurt in this forum. If you knew what you were looking at like the other guy did you wouldnt have pointed out completely wrong gaskets i had already said were not it. Man up sucka. He answered correctly and it was exactly what i needed, which you still didn't produce a correct answer yet. Lol. You're as stubborn as the other guy in another thread that won't let his pride down, but i don't give the slightest damn. You're just another user id on the interweb so either way is fine by me bub.
Old 07-04-2013, 11:10 PM
Doublevision
I can find the oil adapter plate to block, but I can't find the barrel part that the filter itself connects to and the coolant outlet is on. What is that round part called?
http://forums.corral.net/forums/gt-s...r-housing.html
The '98 unit is on the right, the '00 unit is on the left. The big honkin' thing is the oil cooler, which attaches on the adapter (just imagine the big thing sliding a bit to the left over the adapter). The coolant hose connects to the big tube at the bottom of the pic (which faces the front of the motor) in both cases, just with the oil cooler it connects to the cooler and without the cooler it just connects to the adapter. To do away with the cooler all you gotta do is replace the adapter with the non-cooler adapter.
So anyway I guess the round part itself doesn't seem to have a name of it's own, but more importantly if I can just eliminate the cooler part and use the non-cooler one that would be good too. Anyone want to confirm? I am having mixing issues in that cooler assembly.
I guess I am going to try a 1999 Lincon Town car plate adapter.
drfister
05-03-2018 10:38 PM
mirandaandjimmy
11-16-2015 08:51 AM
mtxplod
08-29-2015 01:43 AM
soulcaliber39
08-26-2015 03:26 PM
Quick Reply: Why don't these intake gaskets appear anywhere online?
