HELP with this mustang
Old 07-29-2013, 03:33 PM
the5schlueters
the5schlueters's Avatar
Default HELP with this mustang
I have a 96 gt conv. that I want to kinda trick out. I want some power and some style lol. I have built many fast cars and what not over the years just never messed with the 4.6l. Here is what I got I bought the bbk 78mm tb the bbk cold air intake and some uridium plugs. I ordered a set of romeo pi heads and getting ready to order the intake manifold to do the pi swap. I am looking at superchargers and turbos. which one do you recommend SC or turbo? on ebay the twin turbo kits are not bad priced but I dont know if they are junk or not. the car has 115k on it should I rebuild it from the bottom up before giving it forced induction or will it hold up? It runs great and sound great. just getting a little lost here and want to put the money in the right places. am I going to have a compression issue with the pi heads? I also ordered lowering spring and struts, slotted rotors (so I can stop lol) here are a couple pictures of it.
the5schlueters is offline
Old 07-29-2013, 03:49 PM
antwaan
antwaan's Avatar
I've read where people discourage running F/I on a pi swapped motor but most people say running low boost is fine.
Don't forget gears.
antwaan is offline
Old 07-29-2013, 06:33 PM
the5schlueters
Don't forget gears.
Do you know what it changes the compression to?
Old 07-29-2013, 06:56 PM
Stevo86
Stevo86's Avatar
High 9's maybe 10:1 you would have to do the math to be certain. It's all a matter of budget really. If you have the money then by all means build the short block and hit it with the boost. Don't forget the supporting fuel mods etc.
Just a quick tip as well if you don't have any experience with mod motors don't forget to properly torque the spark plugs. Every other engine I just put them in, but these engines are notorious for blowing out plugs which is a huge hassle. 12-15ft lbs is what they should be at.
Stevo86 is offline
Old 07-29-2013, 07:53 PM
the5schlueters
Good to know thanks. forgot about the 5.4 and 4.6 plug issue.
Old 07-29-2013, 08:02 PM
school boy
school boy's Avatar
stevo is close, pi swapped cars are right at 10.5 to 1. boost can be run but at low levels. With higher compression, it takes less boost to make the same hp as a low compression engine.
school boy is offline
Old 07-29-2013, 09:35 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Here's an option:
http://www.uprproducts.com/hellion-96-98-gt-turbo.html
Of course, I'd recommend upgrading the rest of your suspension too.
UPRSharad is offline
Old 07-30-2013, 01:57 PM
the5schlueters
Originally Posted by UPRSharad
Here's an option:
Thats a expensive one lol nice tho. Think I am gonna start a little less expensive. It seems like every darn thing that I order has some sort of problem. and to top it off I looked under the car last night and low and behold a pool of trans fluid. Its leaking around the pan gasket. Whoever put the pan on didn't do a very good job gotta fix that today. Was thinking about doing the jmod on it and what not while I got it apart (if everything looks good once I get the pan off). It shifts fine don't slip or anything so I am thinking (praying) its ok. May have to pull it and do the front pump seal and tail seal. will see when I get pan gasket changed gonna do the screen at the same time. apparently they pressure washed it good before I bought it it was clean. But thats the only leak I have found so far.
Old 07-30-2013, 09:04 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Yeah, I mean, you definitely need to prepare the foundation before you add boost. The entire car is the foundation.
Old 07-31-2013, 12:05 PM
the5schlueters
thats my plan I usually work from front to back (motor to rear end) but I think I am going to go from back to front this time.
Quick Reply: HELP with this mustang
