2000 GT
Old 08-06-2013, 05:38 PM
Cpeery
Cpeery's Avatar
Default 2000 GT
Hello everyone this is my first mustang I have had it for about a month I've replaced the basics, timing belt, spark plugs , wires.all I know from what the guy told me he did is put a short shift in it which leads me to my first of three questions.1. I've noticed when im shifting in neutral or turning it sounds like the whole transmission is going to fall apart, like a rattle sound almost only when in neutral and turning feels fine shifting first sometimes I have to fight but normal shifting ok.2 went to replace the alternator today and the one I bought from AutoZone did not fit it was a inch to big, so I am forced to have to go to Ford for this I'm curious why it didn't fit it was the right replacement we double checked twice but it was not the size of the one I pulled out which is factory, and third I have a high squeak coming from the right front tire thought it was the hub bearing replaced it it is still there not ask the time but in and out from time to time like a high pitch squeak any comments would be appreciated Ty
Cpeery is offline
Old 08-07-2013, 08:43 AM
harbre32
harbre32's Avatar
You don't have a timing belt. You have a chain that doesn't need replacing. Serpentine perhaps? The squeel could be your power steering
harbre32 is offline
Old 08-07-2013, 11:00 PM
Cbird
Cbird's Avatar
The short throw shifters have much less "padding" in them to muffle normal tranny noise. I know the stock shifter has a ton of rubber noise dampening in it. If you made a video I bet we could tell you if it's normal or not.
Rattling doesn't exactly sound normal, but it could just be normal tranny vibrations causing the noise.
I have the same squeak coming from the front right too. I notice it mostly when I accelerate in 5th gear? Is this the same for you too? If so I will try to track down the squeak in my car and relay the info back to you
Cbird is offline
Old 08-07-2013, 11:33 PM
Sonic Mustang
Banned
Sonic Mustang's Avatar
My Steeda Tri Ax shifter has NO rubber insulation or padding of any kind. It vibrates, heats up and transmits transmission noise into the cockpit much more than the OEM shifter. I hear noises I never heard with the stock shifter. A couple of passengers have commented about transmission noise.
The best way to judge your experience is drive similar Mustangs with aftermarket shifters. I'm pretty sure the NVH I experience is normal because I installed my Tri Ax when the car was new and the NVH hasn't gotten worse over nine years.
Sonic Mustang is offline
Old 08-08-2013, 09:53 AM
Cpeery
Cpeery's Avatar
Power steering checks out, chain is new
Cpeery is offline
Old 08-08-2013, 09:56 AM
Cpeery
Cpeery's Avatar
That does make me feel better I appreciate the responses Ty
Cpeery is offline
Old 08-08-2013, 09:57 AM
Cpeery
Cpeery's Avatar
no only like at slow speed the faster I go it disappears abs it's not a constant thing
Cpeery is offline
Old 08-08-2013, 12:42 PM
uberstang1
Chupacabra
uberstang1's Avatar
Who changed the timing chains?
uberstang1 is offline
Old 08-08-2013, 06:43 PM
Cpeery
Cpeery's Avatar
Dealership
Cpeery is offline
Old 08-08-2013, 08:52 PM
Cbird
Cbird's Avatar
Yeah mines not constant either. Seems to happen only when my pedal is pressed down just a little, like light acceleration.
I bet my car makes the sound at low speeds too, it just gets blared out by the exhaust haha
Cbird is offline
Quick Reply: 2000 GT
