My speedometer is intermittently way wrong.
Hi all.
I noticed I was supposedly going 96 miles an hour on a busy highway a few months ago. As if! Since then I've noticed the speedo reading crazily high on the highway once in a while, and sometimes low around town. The thing's clearly going bad.
This is a '96 Cobra. Anybody have experience fixing this kind of problem? I'm not against taking it apart.
I'd like to keep the stock look, so if replacing it with a more-reliable technology is an option, it'd need to use the stock gauge. Thanks for any insight!
Gavin
Gavin
Thanks for that. I'm going to have to check the things mentioned in that first thread:
Bad VSS sensor.
Bad/worn gears driving the VSS sensor.
Bad wiring (short, stray voltage on GY/BK wire or loose connector)
Missing/weak ground on the PK/O wire (G201 located behind I/P at RH Cowl).
Bad alternator diode causing exessive AC ripple.
Bad VSS sensor.
zanemoseley
09-06-2015 12:58 PM
