Speedo not working
Old 08-28-2013, 07:04 PM
aford89
aford89's Avatar
Default Speedo not working
I have a 1996 GT Auto. Recently (sitting overnight) the speedo stopped working and the O/D light just flashes. when i bought the car the ABS light was on and everything still worked i did have to get a speedcal and fix to compensate for a gear change in the rear end. I have changed the VSS to aval on getting the speedo to start working again. I am out of ideas any guru's know what i should be doing next?
Thanks in advance let me know if more info is needed
aford89 is offline
Old 09-02-2013, 07:05 PM
WJL
WJL's Avatar
Check the connector at the VSS, if the o-ring goes bad you can get automatic transmission fluid in the connector and short it out. Disconnect the connector spray some electrical contact cleaner in the connector and VSS and blow out with compressed air reconnect and check. you can also check for reference voltage, using a voltmeter. with the key in the on position (engine not running) the reference wire should have 5 volts. if no voltage you have other issues that will require additional diagnoses
WJL is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
Pyrate Dave
09-10-2015 07:30 PM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Speedo not working
