Knocking on start-up...opinions?
Old 09-20-2013, 02:46 PM
Indy-Vert
Indy-Vert's Avatar
Originally Posted by Derf00
What weight (viscosity) oil you using? It could simply be the oil is thicker than what you used before so it takes a couple of seconds to get going or the old oil was so worn it was water at startup.
Don't rely on stock gauges to troubleshoot your engine. They are smart-idiot lights.
10w 30 every 3k miles for the last 60k miles.
Indy-Vert is offline
Old 09-20-2013, 02:54 PM
Indy-Vert
Indy-Vert's Avatar
Originally Posted by needmorespeed
I have had some issues with a rough idle on startup. The revs build and drop. This never happends with enough regularity to cause me any concern and is only a few hundred rpm difference. The motor runs fine at all other times, except the lifter tick but that is another story. Also, you shouldn't be revving your motor at startup. I don't know what time frame you are talking about but if you jump in, fire it up and rev it up to 5 grand, that isn't good for your motor. You gotta let everything get up to temp before you start revving it.
As an aside, 3K oil changes are probably wasting your money, owners manual calls for changes at 5k.
The revving never gets up above 2000 or so rpm until the motor is properly warmed up . Even on the coldest days I never encountered any rough revving or idling with this motor until now.
As for the oil change, I'm an old-schooler trained by even crustier old-schoolers to change my oil every 3k...it's engrained into my soul, unfortunately.
Old 09-20-2013, 03:00 PM
Derf00
Gentleman's Relish
Derf00's Avatar
That is fine for that motor so I can't say that's necessarily the reason.... although dropping to a 5W-30 would be worth a shot. Slightly lower viscosity when cold would circulate faster at startup. At temp you still have the same protection.
Derf00 is offline
Old 09-20-2013, 03:09 PM
needmorespeed
needmorespeed's Avatar
I agree your oil probably isn't the problem but why don't you use 5-20. My 04 runs 5-20 and i assume all 99-04 GT's would run the same.
I guess 3K is better than waiting to long!
needmorespeed is offline
jessicarabbit
09-25-2015 12:41 PM
2015Ecoboost
09-17-2015 01:48 PM
degner122
09-16-2015 07:09 AM
rdog69t
SVT Forums
09-13-2015 06:16 PM
Jose Corretjer
09-08-2015 06:32 AM
Quick Reply: Knocking on start-up...opinions?
