Coolant leak 98 GT 4.6
Old 11-21-2013, 07:29 AM
Rustangfb
Rustangfb's Avatar
Default Coolant leak 98 GT 4.6
Losing engine coolant from what appears the rear passenger side of the engine-at intake manifold. Can see a little coolant on the intake but more is dripping from underneath. Does the intake seal a water jacket at the rear of the intake? Suggestions?
thanks
Rustangfb is offline
Old 11-21-2013, 11:36 AM
Stevo86
Stevo86's Avatar
The intake gaskets most certainly seal a water jacket at the back left of the engine and front right. On the older PI engines the intake manifold itself would crack back there and you would need to replace the whole thing.
You're going to need to do a little more poking around to find the source of the leak so you don't replace the wrong piece. I suggest renting a cooling system pressure tester to pressurize the system so you can look for the leak and listen for the hiss of escaping coolant.
Stevo86 is offline
Old 11-22-2013, 07:39 AM
Rustangfb
Rustangfb's Avatar
Stevo86,
thanks for the input. It's in the shop now for a pressure test & quote from there. the intake was replaced a few years ago due to cracking at the tstat, with the upgrade intake. Hopefully it is not cracked at the water nipple pass rear & can just take a new gasket set.
Old 11-22-2013, 07:53 AM
Stevo86
Stevo86's Avatar
Yeah man, best of luck to ya.
Stevo86 is offline
Old 11-28-2013, 05:56 PM
kenny31595
kenny31595's Avatar
Originally Posted by Rustangfb
Stevo86,
Very interested in what you found out ... i have coolant leak in my 2000 gt and cannot locate the culprit.
kenny31595 is offline
Old 11-29-2013, 11:56 PM
71_340
71_340's Avatar
Rent a cooling system tester from your local parts store and pressurize the system....the leak will show (if it is external).
71_340 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Coolant leak 98 GT 4.6
