high idle
Old 01-12-2014, 06:15 PM
tangystang
tangystang's Avatar
Default high idle
I started my car today and it idled really high. I figured it would go down but it didn't. I drove the car for a while and still idled high. And it also does this, when I'm in any gear and I get up to about 3-3500 rpms and let off the gas to slow down without breaking once the rpms drops just a bit then it drops again really far and changes the tone of the car. It runs fine except for the idle.
tangystang is offline
Old 01-14-2014, 10:25 AM
Fryguy22
Fryguy22's Avatar
sounds like your IAC needs either cleaned or replaced.
Fryguy22 is offline
Old 01-14-2014, 11:49 PM
BMWiduch
BMWiduch's Avatar
Most definitely your IAC or your Throttle Sensor might be going bad. Chances are it's probably going to be your IAC.
BMWiduch is offline
Old 06-02-2014, 08:41 PM
HocusFocus763
HocusFocus763's Avatar
What is a IAC & where is it located?
HocusFocus763 is offline
Old 06-02-2014, 09:18 PM
VTX1800N1
VTX1800N1's Avatar
Inlet Air Control. It lets the computer bypass the throttle plate for intake air to control idle speed. It's on the throttle body.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 06-03-2014, 08:34 PM
robb15033
robb15033's Avatar
I did a quick search. I did NOT watch it but it is removed and cleaned, put back on.
robb15033 is offline
Old 06-05-2014, 06:32 PM
HocusFocus763
Replaced the IAC & that did the trick Thanks everyone.
Also found a way to test for this. Place a piece of tape over the two holes under the IAC, reinstall the IAC, start the engine. Mine would run, very low idle, & had to hit the gas to keep it running. It was not at all running at high idle, so I replaced the IAC w/ a new one, problem solved .
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Drastang
09-30-2015 03:48 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: high idle
