I think I broke it
Old 05-09-2014, 11:54 PM
Valnar300
Valnar300's Avatar
Default I think I broke it
I think I broke the mustang (02 GT, manual trans)... Put the new tires on today (274/40/17 from 245/45/17, on the rear only) and after taking a left on the way home I heard a violent clank/clunk noise from the rear. It sounds/feels like the LR tire when it happens, and tends to happen accelerating around corners. It also happens occasionally in a straight line. Its definitely coming from in/around the rear axle. Thoughts?
Valnar300 is offline
Old 05-10-2014, 08:23 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Make sure the tire store idiots tightened the lug nuts--would not be the first time. If they are tight then you have some problem with the LSD clutch pack(s), spider/side gears or maybe broken axle shaft splines.
Another thought, has the differential oil been changed recently? Is so was the proper amount of friction modifier added (if required with the selected fluid)?
cliffyk is offline
Old 05-10-2014, 10:18 AM
Valnar300
Valnar300's Avatar
I'm the idiot that changed the tires, and I tightened the lugs to 100 ft/lb. IDK when the diff oil has been changed last, I just got the car in March.
Old 05-10-2014, 10:54 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Sorry 'bout that...
You will have to pull the differential cover to change the rear-end fluid--take a good look inside when you've got it opened up...
cliffyk is offline
Old 05-10-2014, 11:21 PM
Valnar300
Valnar300's Avatar
Originally Posted by cliffyk
Sorry 'bout that...
No harm, you couldn't have known. Although IF that were to happen to me I'd rather have it happen to my car instead of a customers' car.
Old 05-11-2014, 10:29 PM
5sp04GT
5sp04GT's Avatar
How is the clearance with the new tires to the fenders it may be rubbing.
5sp04GT is offline
Old 05-12-2014, 12:05 PM
Valnar300
Valnar300's Avatar
The clearance is fine, I found the issue
Old 05-12-2014, 12:39 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
That would do it...
cliffyk is offline
Old 05-12-2014, 08:15 PM
Hangwire
Hangwire's Avatar
Hahaha yes that would do it. Weird coincidence man.
Hangwire is offline
Old 05-12-2014, 09:56 PM
5sp04GT
5sp04GT's Avatar
Talking
...well there was kinda a clearance issue maybe
5sp04GT is offline
CMcNam
10-30-2022 11:40 PM
stangin1996gt
09-21-2015 11:01 AM
cbird1177711
09-02-2015 04:12 PM
steelers743
08-31-2015 07:16 AM
Quick Reply: I think I broke it
