Front Right Brake
Old 05-13-2014, 07:38 PM
unibass
unibass's Avatar
Default Front Right Brake
Greetings,
I bought a 2004 GT Convertible last October. The guy I got it from put a few of mods and it appears as though he did a fair amount of racing.
Long story short, there is an abnormal amount of wear on the front right brake. It seems that the caliper won't release after driving for a while. This is causing a lot of brake dust to collect on the rim and, obviously, wearing my pads down.
When I first got the car, I had the rotors and calipers replaced. That didn't stop it. Around January I had the flex hose lines replaced (maybe there was a kink?). Didn't help. Last month I took it to the dealer who swore up and down that everything was fine (except for the after market calipers). No ABS errors. Master Cylinder checked out fine. I took it back to the repair place and had the calipers replaced again under warranty, and it's still doing it. The guy at the shop suggested it might be a proportional valve, but I'm not sure what to think at this point.
Any ideas?
Thanks,
Michael
unibass is offline
Old 05-13-2014, 10:05 PM
5sp04GT
5sp04GT's Avatar
How's the fluid old, new, unknown? If it's old it could have moisture in it causing rust in the calipers or if there is debris in the lines that can cause seizing in calipers. Just had this happen to me in my Toyota pickup after Toyota replaced the rotten frame. They also replaced some brake lines and bam a week later frozen brake caliper.
5sp04GT is offline
Old 05-13-2014, 10:30 PM
unibass
unibass's Avatar
Thanks for the reply. The fluid was replaced with the first caliper change as well as the flex hose. This is driving me nuts.
unibass is offline
Old 05-14-2014, 12:09 AM
VTX1800N1
VTX1800N1's Avatar
Any possible damage to the steering knuckle that could cause misalignment of the caliper to the rotor? Caliper carrier damage?
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 05-14-2014, 09:35 AM
unibass
unibass's Avatar
That's a brilliant point. I wouldn't know how to check that. The car rides really low with the set of springs the guy put on it. Wouldn't that have been something that the dealer or the mechanic would have caught?
unibass is offline
Old 05-14-2014, 07:06 PM
5sp04GT
5sp04GT's Avatar
Depends on how good or thorough they are.
5sp04GT is offline
10-07-2015 07:02 PM
maestro1024
09-21-2015 02:40 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-16-2015 07:53 PM
Quick Reply: Front Right Brake
