How to remove steering shaft?
Old 06-13-2014, 10:29 PM
unitedwestang
unitedwestang's Avatar
Default How to remove steering shaft?
As the title says, I'm stuck on how to get the steering shaft out. Everyone says its simple and straight forward. I like to think I'm fairly mechanically knowledgeable. Hell I rebuilt this car, but geez this has me lost. I've already loosened the pinch bolt at the rack. My problem is: Everywhere I look says remove the bolt on that shaft by the firewall. I'm guessing this means the engine bay side of the firewall. Well, there is no bolt on my engine bay side of the firewall before the u-joint. Just a black sleeve that runs through the firewall with a shaft running through it. Following this shaft into the cab it connects to another u-joint via pinch bolt and ultimately to the steering column. I have also removed the two nuts on the cab side of the firewall holding the plate on. But still to no avail.
Any and all help is appreciated.
unitedwestang is offline
Old 06-14-2014, 12:31 PM
school boy
school boy's Avatar
Should be a pinch bolt under the dash on the shaft.
pdf link here: http://www.maximummotorsports.com/co.../MMST-14r1.pdf
school boy is offline
Old 06-16-2014, 04:48 PM
unitedwestang
Thanks, I had tried that, but I needed to pull the rack off to get room to slip the shaft off. But since I had put new bushings in with the new rack it was pretty darn tight and I gave up for the night. I'm sure I'll be able to get it now.
Thanks again.
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: How to remove steering shaft?
