Engine won't idle when warm
Old 08-22-2014, 04:03 PM
jkm757
jkm757's Avatar
Default Engine won't idle when warm
My 98 GT will not idle at the proper RPM when the engine gets up to operating temp. Normally it idles around 800 RPM when warm, now it's under 500 and I have to keep my foot on the accelerator to keep the engine from stalling. What ever is causing the problem does not trip the check engine light. Any ideas you may have as to whats causing the problem are greatly appreciated. Thanks.
jkm757 is offline
Old 08-22-2014, 04:12 PM
CalBoy101
CalBoy101's Avatar
Could be bad IAC valve, bad IAT sensor (intake air temp), ECT (engine coolant sensor), TPS (thottle position sensor), MAF or a sticky EGR valve, when they stick open they cause idle problems.
Do you have a way to datalog and see what values you are getting from the IAT, ECT, MAF and TPS sensors?
You should also check the fuel pressure.
CalBoy101 is offline
dawson1112
dawson1112's Avatar
Sounds like a dirty IAC . Mine idles at about 1000rpm until it starts to warm up then settles at 800.
dawson1112 is offline
Old 08-22-2014, 05:45 PM
jkm757
jkm757's Avatar
Thanks CalBoy. I'll check the valves and sensors you called out. The car has 175,000 mi. and other then the ECT, all the other sensors and valves you mentioned are original. I do have a code reader to get data codes but I don't have a scanner to read real time telemetry.
jkm757 is offline
Old 08-22-2014, 05:47 PM
jkm757
jkm757's Avatar
Thanks dawson. I'll look into the IAC and see if that's where the problem lies.
jkm757 is offline
Old 08-23-2014, 06:25 AM
uberstang1
Chupacabra
uberstang1's Avatar
check the iac
uberstang1 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
Granatelli Sales
01-20-2020 12:34 AM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Engine won't idle when warm
