pcm reflashed
pcm reflashed
hey guys,i just had a new pcm installed,and programmed,and had only 1
key,they programmed 2 keys,car runs great,but i have 3.73 gears,and i
did not think to tell them what i had,does that really matter?
Go to www.paladinmicro.com, click on the "tools" tab and then click on "gear calculator". Put your info in (rear tire size, transmission etc) and you can compare the differences in vehicle speed at an identical engine rpm and gear.
Just off the top of my head I'm guessing that with 3.73's the speedo will read about 20mph high at 50mph. With these sort of things it's always a percentage.... So it won't be a consistent high speedo reading; at 30 mph it may only read 10 or 15 high, and at 75mph it may read 25 or 30 high.
If the odometer is off by 0.1 per mile, then your speedo is off by 10%.
So at an indicated speed of 50, your actual would be 45. At 60, actual is 54. At 70, actual is 63. Etc, etc.....
An easy way to verify is download a free gps app for your phone and try it while driving.
bryan616fl
01-25-2019 09:07 PM
HIS S-197
08-10-2015 05:47 PM
