1999 GT surges from stop
Old 12-29-2014, 04:19 PM
kazoobers
kazoobers's Avatar
Default 1999 GT surges from stop
I have a 1999 GT 4.6L automatic. When I am starting off either in drive or reverse, sometimes as soon as I put it in gear the car surges with a pretty good force. I know now to have my foot firmly on the brake before I put it in gear. I am afraid though, that someone else driving my car may not do the same if I forget to tell them and they might run into something. What could be the cause of the surging? I don't touch the accelerator when starting so it can't be a sticky pedal.
Thanks.
kazoobers is offline
Old 12-30-2014, 12:40 PM
dawson1112
dawson1112's Avatar
What rpm is your car idling at? Sounds like you have more of a high idle problem. maybe a vacuum leak.
dawson1112 is offline
Old 12-31-2014, 05:38 PM
kazoobers
kazoobers's Avatar
It idles between 1000-1100 rpm.
Old 12-31-2014, 08:30 PM
dawson1112
dawson1112's Avatar
That's too high, it should be around 700-800. Likely have a vacuum leak or your IAC is dirty and needs cleaning.
Old 01-01-2015, 03:21 PM
uberstang1
Chupacabra
uberstang1's Avatar
check IAC/TPS/ Vacum lines
uberstang1 is offline
cr620
10-03-2022 10:18 PM
4cylinderplus2
10-09-2020 07:45 PM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 1999 GT surges from stop
