Throw out bearing updated
Old 01-06-2015, 10:46 PM
Dom99GT
Dom99GT's Avatar
Default Throw out bearing updated
I recently realized that once the car warms up the squeak disappears entirely, every once in a while there may be a small little tiny chirp but it it's extremely quite could this mean the throw out bearing is infact ok but just needs to be lubricated? I'm still getting some clutch pedal vibration so I am replacing the clutch throw out and pilot bearing but I'm thinking the car should be ok to drive since the noise goes away when warmed up?
Dom99GT is offline
Old 01-07-2015, 01:15 PM
Z28KLR
Z28KLR's Avatar
For the most part the only issue with a noisy tob is the noise. Based on my own experience, when they get real bad - which generally takes a while (mine lasted at least another 5K from the moment I first noticed any noise) you will eventually experience clutch pedal issues or issues engaging/disengaging the clutch. By the time the noise became unbearable and constant, the pedal also had a bit of a "ratchety" feel to it and I had to stick my foot under the pedal as to pull it up once or twice due to the bearing sticking. Once it got to that point I just parked it until I got new parts rounded up.
The only real risk with a bad tob is possible damage to the transmission input shaft. But even as bad as mine got that still didn't happen.
Other parts you should consider replacing at the same time as clutch etc is get an aftermarket aluminum quadrant and firewall mounted cable adjuster, along with a new cable (oem or equivalent is what is most often recommended) and some people also elect to replace the clutch fork as well. The factory plastic quadrant has a built in cable adjustment mechanism, but being made out of plastic it is known to flex a bit under hard use which causes engagement/disengagement issues and additionally if you go with any sort of aftermarket "performance" clutch setup it generally does not offer correct cable adjustment which will lead to a shortened life of your new clutch.
Z28KLR is offline
Old 01-08-2015, 11:39 PM
Dom99GT
Dom99GT's Avatar
Thank you you put my mind at ease! i was told some horror storys about the throwout bearing destroying the input shaft but like you said alot has to happen before that like the clutch pedal being hard to engage and i feel like in order to destroy the input shaft youd have to be driving on that bad throw out through it causeing bad engagement and messin uo the clutch. as far as the pedal vibration i seem to get it in first and second and everyonce in awhile when im in gear and slowing down i will replace the shift fork and cable adjuster like you said thanks for the help!
Dom99GT is offline
mrtrodonet
09-19-2020 03:12 PM
6bangr
02-15-2016 07:40 AM
KingRando
10-02-2015 08:06 AM
Drastang
09-30-2015 03:48 AM
Offendant
09-23-2015 07:21 PM
Quick Reply: Throw out bearing updated
