mac lt header install question
Old 01-07-2015, 09:22 PM
Sandmanbjj
Sandmanbjj's Avatar
Default mac lt header install question
I plan on installing my MAC long tube headers and o/r H pipe this weekend. While I'm doing so I'm going to change the clutch and fly wheel along with the associated parts.
Does dropping the tranny make the header install any easier? More room to work?
Are their any step by step guides on the forum for 99-04 V8 header installs? I have searches and find the v6 guide. I'm sure I have most if it figured out from.what I have read here but I would love a step by step.
2001 GT convertible.
Sandmanbjj is offline
Old 01-08-2015, 01:48 PM
school boy
school boy's Avatar
heres some decent info
http://www.mikefordmustang.com/write...mustang-gt.php
school boy is offline
Old 01-08-2015, 02:04 PM
Sandmanbjj
Sandmanbjj's Avatar
Thanks. After looking at that one, I've seen it before I think. Are all those steps necessary? After reading a bunch here I don't see where others pulled apart the struts, tie rods, sway bars and such Also the k member.
Maybe I'm over simplifying this job in my head?
Old 01-09-2015, 07:17 PM
school boy
school boy's Avatar
not all is needed but dropping the kmember might be needed.
Old 01-10-2015, 10:33 AM
Sandmanbjj
Sandmanbjj's Avatar
Thanks for the heads up.
Old 01-17-2015, 10:32 PM
uberstang1
Chupacabra
uberstang1's Avatar
Dont bolt both heads on with the trans out because u wont be able to lift the trans back in. Dropping the k member is simple and makes headers a peice of cake.
uberstang1 is offline
Old 01-19-2015, 12:50 PM
Sandmanbjj
Sandmanbjj's Avatar
So can I bolt up the passenger side header then put the transmission back in, then do the driver side header?
Old 01-19-2015, 01:31 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Bro, I'd get the trans done and re-position the car so you can remove the K-member. its the easiest way to do it. Trying to take shortcuts might burn ya in the end
WhiteFoxGT is offline
Old 01-20-2015, 10:54 AM
Sandmanbjj
Sandmanbjj's Avatar
Whitefoxgt I appreciate the heads up. I'm sure you are right and I'm going to beat myself up. But I got the exhaust manifolds off by jacking up the engine. I'm going to bolt on the passenger side header. Then put the transmission back on. Then bolt up the driver side.
I am doing this by myself and don't think I can handle the entire k member.
Sandmanbjj
Sandmanbjj's Avatar
You will probably get to say...'I told you so".
Quick Reply: mac lt header install question
