Help me with trouble code please
Hey guys, this new 2001 Mustang GT I just bought started earlier today showing the check engine light, I put my scanner on there and it says P1132 and P1152, "Lack of upstream heated oxygen sensor indicates rich bank" Can someone tell me how to fix this?
Thank you.
Thank you.
Those are both 02 Sensor codes.
Here are possible causes
Quote:
Electrical
- Short to VPWR in harness or HO2S
- Water in harness connector
- Open/Shorted HO2S circuit
- Corrosion or poor mating terminals and wiring
- Damaged HO2S
- Damaged PCM
Fuel System
- Excessive fuel pressure
- Leaking /contaminated fuel injectors
- Leaking fuel pressure regulator
- Low fuel pressure or running out of fuel
- Vapor recovery system
Induction System
- Air leaks after the MAF
- Vacuum Leaks
- PCV system
- Improperly seated engine oildipstick
EGR System
- Leaking gasket
- Stuck EGR valve
- Leaking diaphragm or EVR
Base Engine
- Oil overfill
- Cam timing
- Cylindercompression
- Exhaust leaks before or near the HO2S(s)
Source -> http://home.comcast.net/~miracerros/...wertrain_2.htm
Quote:
Electrical
- Damaged HO2S
- Damaged PCM
Fuel System
Induction System
- Vacuum Leaks
- PCV system
EGR System
- Leaking gasket
- Stuck EGR valve
Base Engine
- Oil overfill
- Cam timing
Quote:
Electrical
- Damaged HO2S
- Damaged PCM
Fuel System
Induction System
- Vacuum Leaks
- PCV system
EGR System
- Leaking gasket
- Stuck EGR valve
Base Engine
- Oil overfill
- Cam timing
Quote:
Electrical
- Damaged HO2S
- Damaged PCM
Fuel System
Induction System
- Vacuum Leaks
- PCV system
EGR System
- Leaking gasket
- Stuck EGR valve
Base Engine
- Oil overfill
- Cam timing
fuses would set a circuit code, so skip them, i would check to see if my air filter and MAF (mass airflow sensor) are plugged or dirty. this will give the pcm incorrect airflow readings and will cause you to run rich and set these codes. if you have access to a scan tool, check the baro pid, this is measured in Hz and should be around 156Hz at 1000 feet above sea level, if its off a bunch one way or the other, suspect faulty or dirty MAF. i see this all the time
