Anyone use theses Accel Super coil
Old 09-25-2016, 03:50 PM
dlee
dlee's Avatar
Z28LR,
Could be right! I know American Muscle Dyno tested before & after results. Showed a small Hp increase,
dlee is offline
Old 09-25-2016, 11:52 PM
jwog666
jwog666's Avatar
Unless the gain is significant it can be contributed to variances in the dyno itself, single digit gains are imaginary.
jwog666 is offline
Old 09-26-2016, 08:57 AM
dlee
dlee's Avatar
I noticed when I pulled the third coil on the drivers side, the plug well was full of water/oil. The spark plug seemed tight. The old plug looked like the other 7,
Any thoughts on this?
dlee is offline
Old 09-26-2016, 09:37 AM
jwog666
jwog666's Avatar
sometimes the rubber boot doesnt seal and allows water to enter the well, if it was mostly oil you could have, or at one time it had, a valve cover gasket leak, or somebody spilled oil while filling without a funnel.
jwog666 is offline
Old 09-26-2016, 05:27 PM
stevenn1
stevenn1's Avatar
Originally Posted by Z28KLR
I have a feeling the positive difference you noticed has more to do with replacing the plugs (93K is a solid 43K longer than they should have been in there)....
I was thinking the same thing.
I notice the best performance ('02 GT) when I replace mine at every 50k.
I put MSD Blaster coils in this time (with new plugs) at 100k and the power band seems to pull a little harder. I think a BAMA tuner is my next step.
stevenn1 is offline
