EGR problems
Old 11-22-2005, 02:42 PM
David_K
David_K's Avatar
Default EGR problems
I keep getting this check engine light that says something like EGR insufficient flow. anyqways its code P0401 i think. anybody know what this means
David_K is offline
Old 11-22-2005, 02:48 PM
01yellowgt
01yellowgt's Avatar
Default RE: EGR problems
Here is some info that might help. Insufficient EGR Flow
01yellowgt is offline
Old 11-22-2005, 03:49 PM
David_K
David_K's Avatar
SO what do i use to clean this damn thing
David_K is offline
Old 11-22-2005, 10:56 PM
01yellowgt
01yellowgt's Avatar
You can use Carb Cleaner to clean it out. Also check the egr tube going to it to see if it has any build up.
Old 11-22-2005, 11:21 PM
Emann0007
Emann0007's Avatar
HEY! mine says EGR valve excessive flow....
Emann0007 is offline
Old 11-23-2005, 12:42 AM
01yellowgt
01yellowgt's Avatar
ORIGINAL: Emann0007
clean the egr, possibly the a a bad DPF sensor, or the egr valve
Pretty much the P0402(excessive) and P0401(insuffient) are the same
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: EGR problems
