tune up
Old 12-18-2005, 02:19 PM
00stang37
00stang37's Avatar
Default tune up
hey ive got about 96k miles on my 2000 GT i have an intake and exhaust. what should i have done when i bring it for a tune up? and is there anything i should have done extra for the high mileage. thanks
00stang37 is offline
Old 12-18-2005, 02:44 PM
Voodoo
Voodoo's Avatar
Default RE: tune up
You should have the info in your manual but here is some stuff I have.
96,000 Km (60,000 Miles)
Change engine oil and install a new oil filter.
Inspect brake pads, shoes, rotors, drums, brake lines, hoses and parking brake system.
Inspect wheel ends for end play and noise.
Inspect engine cooling system and hoses.
Inspect steering linkage, suspension and (if equipped) driveshaft and ball joints.
Rotate tires and inspect for wear.
Install a new engine air filter.
Install a new fuel filter. (See ADDITIONAL INFORMATION below.)
If equipped, install a new cabin air filter.
Change automatic transmission/transaxle fluid on all vehicles equipped with AX4S, 4F50N, 4R100, 4F27E. Inspect automatic transmission fluid level using dipstick on all other vehicles, if equipped.
If equipped, install new climate controlled seat filters (Navigator, Lincoln LS and Aviator).
ADDITIONAL INFORMATION: If vehicle is registered in California, the California Air Resources Board (CARB) has determined that failure to install a new fuel filter at this interval will not nullify the emission warranty or limit recall liability prior to completion of the vehicle's useful life. It is, however, recommended that maintenance checks be carried out and recorded at the indicated intervals.
Additional checks for natural gas and propane vehicles at this interval include inspecting fuel tanks, as well as draining coalescent fuel filter and installing a new filter.
144,000 Km (90,000 Miles)
Inspect exhaust system and heat shields.
Additional services for natural gas and propane vehicles include inspecting fuel tanks, as well as draining coalescent fuel filter bowl and installing a new filter.
I uploaded the Maintenance info here
Voodoo is offline
Old 12-18-2005, 03:29 PM
00stang37
00stang37's Avatar
Default RE: tune up
ok thanks. i didnt know if i should have the fuel system cleaned out
Old 12-18-2005, 03:37 PM
xx9gt6xx
xx9gt6xx's Avatar
Default RE: tune up
What Voodoo said sums everything up!
xx9gt6xx is offline
Old 12-18-2005, 03:49 PM
00stang37
00stang37's Avatar
Default RE: tune up
ok. nice stang 9gt6
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Sixx
10-05-2015 07:36 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Explosive
10-02-2015 07:45 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: tune up
