Changing oil after storage?
Old 02-01-2004, 05:05 PM
gio_09_75
gio_09_75's Avatar
Default Changing oil after storage?
<FONT size=2>Well I bought a brand new 03 GT and di my first oil change at 1000k and then again at 5000k, it now has 7600k at has been stored since november cause I live in Canada. I will be taking it out in April or May and I have to mention that I let the car run like once a month for 10 minutes or so, do I need top do an oil change or I can tough it out till 10000k.</FONT></P>
<FONT size=2>Thanks</FONT></P>
gio_09_75 is offline
Old 02-01-2004, 08:23 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
It's fine, why did you wait 5,000 miles to change your oil?</P>
Dan04COBRA is offline
Old 02-02-2004, 05:43 PM
kmcferrin
kmcferrin's Avatar
You probably ought to run it more than 10 minutes at a go if you're going to run it during the winter. Depending on how cold it gets in your neck of the woods it will probably take longer than 10 minutes to get the engine and components at optimum temps and work out any moisture or what-not. At ten minutes your just barely letting it get hot then shutting it down, that can cause unecessary wear.</P>
Most people I know just disconnect the battery so that it doesn't run down, crack the window, and let it sit with 1/2 tank of gas. As far as the oil goes, if your oil is dirty then you'll probably want to change it once it comes out of storage, since any dirt/particulate matter will have had plenty of time to settle. If you changed the oil right before you put it into storageyou shouldn't have any problems.</P>
kmcferrin is offline
Old 02-02-2004, 06:08 PM
piston
piston's Avatar
Dan its kilometers so its only 3000 miles (Canada/metric). Anyway gio I store for the winter too and I recommend changing the oil. I think $40-$70 for an oil change is good cheappeace of mind. I also flush the cooling system each springand check/top up all other fluids. If your like me the first few weeks I have her out its pretty much ***** to the wall. </P>
Also I agree w/ kmcferrin. Run it long enough to bring everything to normal operating temps. Some guys like to pull the coil wire (not sure about newer ignition systems) and crank it over a few times to lubricate everything before firing it up.</P>
piston is offline
Old 02-02-2004, 07:29 PM
gio_09_75
gio_09_75's Avatar
<FONT size=2>Weel first of all its 5000km and no milesin our neck of the woods , and the mustang is stored in a heated garage.</FONT>
Old 02-03-2004, 05:25 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
<IMG src=smileys/smiley5.gif border="0"></P>
</P>
Never looked at his location. Stupid me. <IMG src=smileys/smiley4.gif border="0"></P>
Old 02-03-2004, 03:53 PM
vfast
I ♥ Acer
vfast's Avatar
like said let it run til atleast the stat opens as there is water in the exhaust..I would start it every 2 weeks or so..no need to prime it unhooking the coil wire also ingauge the clutch a few times ...before driving it this spring do the following
new
oil
plugs
fuel filter
grease what ever you can
pcv valve
vfast is offline
Old 02-03-2004, 04:11 PM
thePreacher
thePreacher's Avatar
How much did it cost for the heated garage ? (i live in canada as well, whereabouts are you?) and have you ever tried driving the stang in winter? is it even feasible to drive it in the winter in the toronto region? I ask cuz i dont know if i should trade in my 92 camry when i do pick up an 04 or 05 stang or to keep it and insure the camry for winter and the stang for summer
thePreacher is offline
Old 02-03-2004, 04:28 PM
vfast
I ♥ Acer
vfast's Avatar
keep the camry..that's why they make imports*L*
vfast is offline
Old 02-03-2004, 05:21 PM
w11988
w11988's Avatar
Keep the Camry for winter if you can swing it.
w11988 is offline
Quick Reply: Changing oil after storage?
