Is there a way to reduce the clutch pedal travel? It seems like my clutch pedal is about a foot from the floorboard. I don't necessarily want to adjust where the clutch engages, just lessen the distance that I have to stomp that pedal. (I have reset the pedal acc. to the owner's manual.)</P>
as far as I know it adjust automatically when you "reset it"...other than that there is no adjustment on the stock quadrant/cable.... get a steeda aluminum quadrant and fire wall adjuster and cable....then you'll have plenty of adjustment</P>
Climb under the dash. Find the plastic quadrant. Push the adjuster lever down, and hold it...Then move the clutch pedal toward the floor about an inch or so. Let go of the adjuster lever, and as long as the teeth aren't stripped off the quadrant (and they probably are) it will engage closer to the floor. </P>
