FOR ANYONE WITH THROTTLE BODY AND PLENUM QUESTONS
Old 02-03-2008, 10:48 PM
  #21
2000GT4.6
2000GT4.6's Avatar
Default RE: FOR ANYONE WITH THROTTLE BODY AND PLENUM QUESTONS
The only problem with all this.... is that the company doing the selling is the one doing the dyno tests.
MM&FF, which have nothing to sell (usually anyway) have done several throttlebody/plenum shootouts with the dyno. None of them showed gains anywhere close to 10 WHP, and none of them showed gains comparing a 70 to 75MM t/b (at least not more than 1-2 WHP at best).
I made 420 WHP thru a 70mm t/b on 10 PSI.... it must not be much of a restriction, espcially on a boltons only car. My car also made 256+ WHP on stock computer tune, boltons only, with said t/b.
2000GT4.6 is offline
Old 02-04-2008, 12:46 AM
  #22
JayDs Ibanez
JayDs Ibanez's Avatar
good info
JayDs Ibanez is offline
Old 02-05-2008, 02:27 PM
  #23
ucannvrhav2mchpi
ucannvrhav2mchpi's Avatar
tmas99 if that was to me i was pretty much saying the exact same thing as you. And cai + t/b+ plenum + Lower manifold + new heads +new cams + exhaust that's the only way any of them really make a difference or f/i atleast on my np/i car with my heads and intake being as restictive as they are.
ucannvrhav2mchpi is offline
Old 06-28-2008, 01:01 PM
  #24
kushal_22
kushal_22's Avatar
I too Am looking at this as my Next "Bolt On" and reading this has pretty much answerd all my questions....all but one. Is this something i can put on myself in my Garage and if so how long should it take?
Thanks
Mal
kushal_22 is offline
Old 06-28-2008, 02:25 PM
  #25
defconfire
defconfire's Avatar
You can do it in about an hour or less in your garage with just basic hand tools.
Now Does anyone know any numbers for a professional products setup?
defconfire is offline
Old 06-28-2008, 08:23 PM
  #26
kushal_22
kushal_22's Avatar
Wonderfull! Thanks.
After I asked the question i Found a "Sticky" it showed how to Port the OEM Plenum. So i guess I jumped the Gun a bit there.....My Bad. I think I would rather just buy a new Plenum for the peace of mind that it will all fit and workas supposed to i will pay the 100 to 120 bucks
Thanks for your replies guy`s.
Mal
Old 06-28-2008, 08:48 PM
  #27
jmsjags
jmsjags's Avatar
i need a throttle body to go with my KB. i can pick up a BBK for $200 and i've heard they're on par with Accufabs. should i go with that? are all the throttle bodies pretty much the same performance-wise?
jmsjags is offline
Old 06-28-2008, 09:10 PM
  #28
cliffyk
TECH SAVANT
cliffyk's Avatar
The OEM plenum is an inherentlyhobbled design, as it could have been made taller and allowed better flow through the elbow.No amount of porting can fix this, all aftermarket plenums are 5/8" to 3/4" taller and produce far better flows that the OEM plenum.[/align][/align]Here is my reformatted and annotated version of Accufab's flow bench data, a link to their original data is provided...[/align][/align]And, as many have said, those HP gain numbers posted in the original thread are a load of crap...[/align]
cliffyk is offline
Old 07-17-2008, 01:23 AM
  #29
palerider22
palerider22's Avatar
what is the best tb and mas combo for a pretty much stock 96 stang
palerider22 is offline
Old 07-17-2008, 05:14 AM
  #30
cliffyk
TECH SAVANT
cliffyk's Avatar
If by "pretty much stock" you mean that no exhaust work has been done then do that first before spending money on a TB & plenum. A catted (or o/r if you wish) 2-1/2" X or H-pipe, and 2-1/2" catback will be far less restrictive then the stock exhaust and give a noticeable boost at higher revs.[/align][/align]Next, for a non-PI engine and 'twas me, I'd get a premium fuel tune (93 if you can get it) which will add considerabletorquebetween 2000 and 4000 rpm due to the timing advance possible with the higher octane fuel.[/align][/align]The plenum is the weak point in the OEM intake* and since thevolumetric efficiencyof the non-PI engine is not all that great (that's whyFord was able to add 35 HP with the PIchanges)the stock 65 mm TB is probably sufficient if mated to almost any aftermarket plenum.[/align][/align]As for the "best TB/plenum", Accufab's is generally considered to be the best-best however the TrickFlow/Professional Products (they are the same) cost about 1/2 as much and offer 95%+ of the performance. And again, and I do mean to harp on this, on a non-PI engine (even with a tune) an aftermarket TB/plenum will add very little noticeable gain.[/align][/align]======================[/align]* - Here areAccufab's flow numbers (reformatted)for a variety of TB/plenum combinations, you'll see that the 65 mm TB onany aftermarket TB will flow enough air to keep a non-PI engine happy.[/align]
cliffyk is offline
Quick Reply: FOR ANYONE WITH THROTTLE BODY AND PLENUM QUESTONS
