Nitto 555R on 9 inch wheel....275 or 315?
Old 12-30-2007, 08:21 PM
99GTvert
is my username.
99GTvert's Avatar
Default Nitto 555R on 9 inch wheel....275 or 315?
I have 555R 275s on my current wheels which are 17x8. They look ok, but I also have another set of wheels with 275 tires and they look massive in comparison to the 555Rs.
I'm going to switch to a 17x9 inch wheel. Will the 275 Nittos look a little wider, or should I go with 315 Nittos? I put on a set of 17x9s with 275 BFG drag radials, and the car looks sick. [&:]
99GTvert is offline
Old 12-30-2007, 08:22 PM
steve0914
steve0914's Avatar
Default RE: Nitto 555R on 9 inch wheel....275 or 315?
can you put 315's? on 17x9? i thought you needed atleast 10.5's
steve0914 is offline
Old 12-30-2007, 08:25 PM
99GTvert
is my username.
99GTvert's Avatar
With most other tires, yes the 315s are too big for a 9 inch wheel, but I read somewhere on here that the Nitto 555R 315 tire is small enough to fit a 9 inch wheel.
I just wonder if the 275 555R will look wider on a 9 inch wheel when compared to an 8 inch wheel.
99GTvert is offline
ZW99GT
ZW99GT's Avatar
Oh no. Here we go again. The 315 555r is not as wide as other 315's. I ran them on my 17x9's and they looked great, and performed even better.
ZW99GT is offline
BleedinBlue
BleedinBlue's Avatar
I think* Nitto 315's fit on a 9" wheel because they run slimmer than most brands. It would be most helpful if someone had pictures.
BleedinBlue is offline
Old 12-30-2007, 08:26 PM
Sxynerd
Sxynerd's Avatar
^^ What those guys said!
Sxynerd is offline
Old 12-30-2007, 08:27 PM
99GTvert
is my username.
99GTvert's Avatar
Nice pics ZW!
Thanks, that post just made up my mind.
99GTvert is offline
steve0914
steve0914's Avatar
ORIGINAL: ZW99GT
what tires are those? size?
Old 12-30-2007, 08:33 PM
Sxynerd
Sxynerd's Avatar
^ question.... Can you read???
Sxynerd is offline
Old 12-30-2007, 08:35 PM
lizzyfan
Underboss
lizzyfan's Avatar
I have 555 315 Nitto's on a 10.5 rim and they are a "just fit"! I'd say you'd be fine putting Nitto 315 on a 9!
lizzyfan is offline
Quick Reply: Nitto 555R on 9 inch wheel....275 or 315?
