removing passenger door panel
The guy I bought my car from pretty much blew the factory mach speakers. Trying to replace them and cant get the panel off. I removed the the switch and handle bezels. I removed the push pin in the front of the door. It almost wants to come off but will not. Is the mach 460 tweeter in the way by the window to push the panel up from the clips that its held on by?? What do I do to finish getting it off. Thanks for any help. Jerry
Assuming you also removed the two black screws that sit behind the door handle you should be able to slide the panel up, out and off. You'll have to remove the tweeter for sure to get the panel back on, though.
Removal
This might help a little as well..
Remove-door-panel-mustang
Good luck...
jessicarabbit
09-25-2015 12:41 PM
