how fast can a mustang be
Old 03-24-2008, 01:31 PM
5speed01GT
5speed01GT's Avatar
Default how fast can a mustang be
i seen magazines with stangs that pull out like 800-900 hp and do quarter miles in like 6-7 seconds
then i see amagazinewit brand new z06 that said smoke em cuz you definitly caught and said 7.0 liters 0-60 in 3.7 and tops out at 198
so im wondering if money wasnt much of an issue how much would it cost to get a stang hitting 200mph+ over 1000 hp, 0-60 in 3.5 and the capabilty to pull a quauter mile in under 10 seconds
and im guessing it would be the best if it was done with a corbra or gt 500
imput please
and remember im most interested in how much it would cost to do the work with parts and labor
and for those of you that have pretty good stats like 500 hp and 10 second quarters let me know how much youd be willing to sell your car for
thanks
5speed01GT is offline
Old 03-24-2008, 02:38 PM
Adam03GT
Adam03GT's Avatar
Default RE: how fast can a mustang be
Um...
http://youtube.com/watch?v=W_6OG4xQE...eature=related
You are acting like it is as simple as do a few things and BAM 1000hp.
FIrst off... Dont worry about buying someone elses monster if you dont have the knowledge or pockets to take care of it.
If cars like you speak of were that simple to create then..... everyone would have one?
To make a car even reach 500rwhp it takes hard work and know how. If you are wanting to do stuff like 1000rwhp+ in a mustang you are basicly going to be stripping it of the motor, rear, transmission, EVERYTHING and starting from scratch.
Adam03GT is offline
Old 03-24-2008, 02:45 PM
sstang
sstang's Avatar
You dont need 1000hp to out run a Z06
sstang is offline
Old 03-24-2008, 02:46 PM
jmac72187
corner carver
jmac72187's Avatar
That question is goign to take a ridiculously in depth answer. It wouldn't be just a simply thing.
jmac72187 is offline
Old 03-24-2008, 02:49 PM
hpwrestler220
hpwrestler220's Avatar
just throw a supercharger on you car. push around 375rwhp 400tq and get a great suspension set up and you will be very happy.. you dont need all that horsepower. especially considering you seem to be clueless and you are probably young like me
hpwrestler220 is offline
Old 03-24-2008, 03:15 PM
kenv
kenv's Avatar
$$$x$$$= cubic horsepower. How fast do you want to go
kenv is offline
Old 03-24-2008, 05:32 PM
majinprodigy
majinprodigy's Avatar
Ive personally seen a certain someones modded cobra running 15x in straightways @ willowsprings track, its not exactly meant for top end speed but its got the suspension that certainly matches or even out does a corvette.
One of my books called BUILDING A 4.6 AND 5.4, ATI does a crazy supercharger set up with a massive centri. and insane intercooler, im pretty sure the S/C system alone costs around 15,000 the engine they used was a 5.4 block, i believe it was a 4v but dont quote me on it will heads, cams, FAST system and some other goodies; on the engine dyno is pulled like 1250 hp and like 1000 lbs tq but the HP was wayyy high in the powerband like around 6-7k rpm range.
im pretty sure this set up would not last DD on the street BUT to answer your question...
to hit 200 MPH you need very low drag and good aerodynamics as well as an intense ammount of downforce so the car can steer when your going at that speed.
to hit a 3.7 0-60 you need either an intense AWD system with alot of TQ or a RWD system with big fat sticky tires, fully prepped suspension and a lightweight body probably 2400-2700 pounds max.
to go 1/4 in under 10 seconds again youd need a fully prepped race suspension, sticky tires and some very steep gears
the problem with all this is while the gearing helps you go quick in the quarter it will limit your top limit which is where you need to make up with it with an over drive 6th gear that will be able to still make power.
http://en.wikipedia.org/wiki/List_of...y_acceleration
look up each one of those cars and notice what they all have in common and it will answer your question as to what youd need to get a mustang to do what they do
majinprodigy is offline
Old 03-24-2008, 05:58 PM
01snake
01snake's Avatar
as fast as how deep your pockets are
01snake is offline
Old 03-24-2008, 06:11 PM
01redstang
01redstang's Avatar
I could ask you over 100 questions bro.... But at the end of the day its all about $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$ to make any car as fast as you want
01redstang is offline
Old 03-24-2008, 06:23 PM
ColinGT
ColinGT's Avatar
As fast as you want it to be? If your going over 600 hp your gonna need to probably redo everything if your doing it in a GT.
ColinGT is offline
Quick Reply: how fast can a mustang be
