Cheap Short throw shifter!!
was looking into buying a steeda or pro 5.0 shifter. Instead of buying the kit, I found a pro 5.0 shifter handle lying around. Bolted just the handle onto the stock shifter and BANG short shift. Feels good , much shorter and clicks right into gear. I don't know if it is necessarily shorter throws, but it'll work until christmas. Anyone see any problems with this setup????
Regardless of swapping the handle, it's still the same old crappy stock shifter. Christmas can't come fast enough my friend! Once you get a Tri ax, MGW or Pro 5.0 you will see what a difference they make.
It's just like getting exhaust, it sounds way better than stock for a month then you want it louder. So maybe this will last a week before it feels like a noodle again. I am buying some other things for the car now so i needed to put that aside. The handle is better than stock though.
junior04
09-28-2015 10:53 AM
