(02mustang)Want to put in a Typhoon Intake Manifold. Is it worth it?
hey wutsup, just need some advice. I want to put in a Typhoon Intake Manifold in my 02 gt automatic, http://www.americanmuscle.com/typhoo...904-satin.html
Do you guys think it's worth spending the money? How many ponies are we talkin? I know if I put this intake in with some Stage II Cams, I would be gaining at least 30whp.
Short answer. No.
Do some research, you will lose power, and only gain on 6k+ rpm. Useless unless you have cams and/or ported heads. Stick with the stock intake manifold, and spend that money on getting cams or something else.
Are you trying to set a record for the most amount of threads on page 1?
Do some searching man, there is a search button in the blue bar towards the top of this page. Every thread that you have started has been covered at least 10 times already this year.
BTW the Typhoon is not worth it as I stated in the other thread.
Personally, if I was to get anything, I would get the Trick flow or the bullitt.
