I'm using the special forces software, the only selections i've made so far are for the cold air intake and catback. I've not touched the AFR modifier at all as of yet. Tips would be appreciated
Tip #1, put some 93 octane gas in there (run at least 3/4 tank through), then select 93 octane in SF and add 2.0° to the Global Spark Adder, and 0.5°, 1.0°, and 1.5° to the low/mid/high spark modifier values.
Do NOT mess with fueling until you get a wideband O2 sensor.
If you live somewhere that is consistently HOT (90°F+)in the summer, install a 180°F thermostat. That will lop 20°+ off the coolant temperature and let you run 0.5° to 1.5° more advance.
Oh, did I mention "Do NOT mess with fueling until you get a wideband O2 sensor."
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
-cliff knight- My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
91 octane max in California FTL. Would you still suggest adding any amount of spark? I'm already pretty hesitant to mess with A/F until I get a wideband, so i'm definately gonna leave that alone for now. Where can I find a good 180 degree thermostat?
__________________
03' Mach 1
Sniper Tune
JLT RAI
Flowmaster Mufflers
Steeda Tri-Ax STS, FRPP 03 Cobra Clutch
H&R SS Springs, MM C/C Plates, Steeda X-2 Ball Joints, Steeda Bumpsteer Kit
