Do I need a tune/reflash
Old 09-22-2009, 10:02 AM
V8heat
V8heat's Avatar
Default Do I need a tune/reflash
I recently swapped out my 2000 4.6 motor for a 2003 motor (long story). In addition , I have a CAI, long tube headers and a Borla Exhaust. My car has an idle issue and occasionally the CEL comes on, but then goes off. The idle issue is definitely computer related, because I replaced everything that would suggest it could be mechanical. Should I be considering a re-flash or a tune?
V8heat is offline
Old 09-22-2009, 04:06 PM
dimebag
dimebag's Avatar
I would, only because of the lts tho
dimebag is offline
Old 09-22-2009, 04:21 PM
jeffampt
jeffampt's Avatar
I am pretty sure when you install longtubes that you will need a new tune....at least my friends did after we installed.
jeffampt is offline
Old 09-22-2009, 04:57 PM
lilcrate
lilcrate's Avatar
Yes I would get a tune...
lilcrate is offline
Old 09-22-2009, 06:07 PM
pcs
pcs's Avatar
a retune should help, but was not necessary on my gt. when i fist installed my lt header i had a bbk o/r x pipe, flowy cat back bbk tb, c&l plenum, bbk intake along with mil eliminator and i had no probs with check engine lights or idle issues. could be something else.
pcs is offline
madmaxdvl
05-29-2007 08:22 PM
Quick Reply: Do I need a tune/reflash
