Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 03:20 PM   #1
00infernoGT
2000 Ford Mustang
Vehicle: 2000 Ford Mustang GT
Default Quarter-Mile Times
So does anyone think High 11's are possible out of Fresh Rebuilt 2V, Headers, 4.10's, Long tubes w/ Full exhaust. and 150 Shot WET? I'm building my engine right now and i'm hopin this will be enough for now with my budget. OH and CAI and 75mm throttle body. 29lb injectors! (all this running drag Radials)
__________________
LS-What?
00infernoGT is offline   Reply With Quote
Old 11-03-2009, 03:26 PM   #2
tws1098
Vehicle: 2000 Mustang GT
umm no
What you have sounds like low 12s. You did not list the suspension, tires, other supporting mods to back 11s in my eyes. A lot will depend on how good of a driver you are. But if you are good and conditions are favorable (you get traction) then I think you could crack the 11s no problem.
__________________
2000 GT 5-speed
Questions about 4v heads on a 2v, eaton on a 2v, gears, cams? LOOK HERE! - http://mustangforums.com/forum/4-6l-...formation.html
tws1098 is offline   Reply With Quote
Old 11-03-2009, 03:36 PM   #3
tws1098
O and this belongs in the general discussion section for future reference. This is the technical section.
__________________
2000 GT 5-speed
Old 11-03-2009, 03:40 PM   #4
00infernoGT
2000 Ford Mustang
I am running full stock suspension that I know of with Nitto DR's. I made back to back 13.81 Passes last summer. Spun through 1st and part of second. was running 3.27's without spray or headers on 130000 miles at the time. Those passes were on 255/45/17 Street tires. Dont remember which tire exactly though. My car will be back with the fresh engine this weekend and im just anxious on how well it will run
__________________
LS-What?
Old 11-03-2009, 03:51 PM   #5
mrtstang
Vehicle: 2004, Ford, Mustang Gt
I run Nitto dr's with a 100 shot (mods in sig) and stock suspension. There is no way i'll touch 11's with this setup. It's not so much the lack of power you'd have (a 150 shot would definantly get you in the 11's) as it is stock suspension and Nittos. At minumum you'll need a stickier tire.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is offline   Reply With Quote
Old 11-03-2009, 04:01 PM   #6
00infernoGT
2000 Ford Mustang
alright thanks. I'm about to order a matching set of rims for my car only in 15's so i can get some dr's with sidewall. UCA's and LCA's are next week
__________________
LS-What?
Old 11-03-2009, 05:05 PM   #7
JayC
With the right tire, yes!
__________________
SCT tuned by Greg @ Speedy Dyno
12.51 @ 108 w/ CMS stage II cams
11.35 @ 120 NX
JayC is offline   Reply With Quote
Old 11-03-2009, 11:09 PM   #8
ddmsgtr1
Vehicle: '02 GT
With the right tires and suspension, and depending on what's in this built 2V (heads, cams, compression ratio) I think you should be able to run low 11s if you drive it. If you plan on alot of drag racing, get solid bushing control arms.
__________________
'02 GT
SLP LM1, Bassani catted X, BBK shorties, BBK CAI, RPMOutlet.com U/D pullies,
Strange 10ways, built 8.8 w/ 4.10s, Nitto 315 DR's, MGW STS
ddmsgtr1 is offline   Reply With Quote
Old 11-04-2009, 10:27 AM   #9
tim2002gt
2002 Ford Mustang
tim2002gt's Avatar
Vehicle: 2002 Mustang GT
I agree with JayC. The right wheel/tire combo will get you into the 11's. You may not even need a 150 shot. I've done it with a 125 shot. Honestly, if you couldn't run 11's with the 150 shot I would think something was wrong.
My best is an 11.78 @ 116 with the mods here... http://mustangforums.com/forum/garag...tim2002gt.html
__________________
tim2002gt is offline   Reply With Quote
Old 11-04-2009, 05:05 PM   #10
sv650lex
Vehicle: 2001 gt convertible
Quote:
I agree mysilverado ran an 11.9 on a 150 shot with bolt ons and a cam. A bit more power then a 4.6 but a bit more weight.
A perfect launch never hurts either.
sv650lex is offline   Reply With Quote
2010, mile, quarter, times
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
