The difference between a modular and a 5.0?
They both have valves and cam(s)--the difference is that in the overhead valve 302 (5.0) there's only one camshaft located in the center of the block and the valves are opened by lifters that ride on the cam lobes, and pushrods that cause rocker arms in the head to pivot and open the valves.
On the overhead cam engines there are one or two camshafts located on top of the cylinder head. Cam followers ride on the camshaft and open the valves directly, rather then through pushrods.
On our cars the cam followers are pivoted levers with a 1.8:1 ratio. The follower is supported on one end by a hydraulic lash adjuster (HLA) pivot point, a roller in the middle of the follower rides on the cam, and the other end of the follower operates the valve.
In this photo the HLA is in the foreground:
Here's a great animation of the Ford GT engine's operation...
Suck, Squeeze, Bang, Blow...
the term "modular" doesn't really describe the engine design itself, i think it was originally used to describe the assembly line technology used to put the motors together and the name just sort of stuck. Ford can use the same assembly line to assemble several different motors.
the "modular" engines are quite a bit different than the old pushrod 5.0's but as cliffyk described above, a big difference is the overhead cams on the modular compared to the single cam in the block of the 5.0. the modular engines eliminated the pushrods and lifters in the valvetrain, replacing them with cam followers and lash adjusters.
I think what gave rise to the term being associated with the engines, is that one block casting can support parts from different versions of the same engine family. An example would be a 4.6L block being able to accept either 2V SOHC heads, or 4V DOHC heads, two totally different head configurations able to be interchangable on a single block.
10-09-2015 03:27 PM
stangin1996gt
09-21-2015 11:01 AM
