What fuel pump do I need?
I have a little cash and wanted gears BADDDLY, but then realized that I need a fuel pump. I have to switch the key to the on position unil the whine stops... and then fire up the car, otherwise the car will sort-of misfire if I try to accelerate. :/
I don't know much about fuel pumps, so I ask for assistance.
I have a 96 gt with shorties, o/r x-pipe, flows, ram clutch, nitto dr's, 04gt motor.
Soon, I plan on doing 3:73 or 3:90 gears.
Also, how much is he usual amount paid for labor?
i found this: http://losangeles.craigslist.org/sfv...695378890.html
any input would be nice
If you want to go bigger just get this http://www.summitracing.com/parts/VPN-GCA719-2/
A Focus pump is not gonna work on his return style setup
Sorry about that OP.
Do you know how much is labor?
I'm looking at like $150/labor + $130/pump. thanks again
Another thing, why would I want to go with a bigger pump? Will I gain more performance? Will I use more fuel? Why not go with the stock lph the 04gt uses?
From what you have on your car you don't need a better flowing pump unless you have some sort of forced induction or nitrous.
If you're doing this in the future though you might as well put the better pump in now.
