Seafoam Fuel Treatment System
Old 05-09-2010, 08:42 PM
ResQman
ResQman's Avatar
Default Seafoam Fuel Treatment System
I have searched and had some success in How to use Seafoam to clean the Fuel injectors/System and had some success, but, I would like to know if anyone has used this product and if you have any Directions on EXACTLY how to use it andwhere.
Thanks!
ResQman is offline
Old 05-10-2010, 03:43 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
What problems are you experiencing that make you believe you need to "clean something"?
Seafoam was developed in the late 40s/early 50s to clean gunk out of improperly operated/maintained/stored marine engines--that's the "sea" part.
Unless you '06 Mustang has been run being cooled by ice cold seawater, never had the old changed, or stored all winter in a shack out on a dock, you probably don't need to run any snake-oil through it...
cliffyk is offline
Old 05-10-2010, 11:57 AM
0949er
0949er's Avatar
This is how seafoam goes down on MF:
1) A OP asks about Seam foam
2) a seasoned MF poster says its the worst thing out there....
WTF IS sea foam? Snake-oil? I know you just said what it was used for... but I mean, is this stuff claimed as some multi-purpose end-all be-all product? And for that matter, why does EVERYBODY that seems to know something about it say its the worst **** for their car there is?
0949er is offline
Old 05-10-2010, 11:59 AM
ResQman
ResQman's Avatar
LOL...No.
I assume that the fuel system needs to be Cleaned out, specifically the injectors. I have had my injectors cleaned (on other vehicles) at a Oil Change place using a bottled injector cleaner but thought that it could be done at home.
After looking here and throughout the rest of the forums, several others have done this maintenance as well but just looking for someone who may have the "Exact" procedure down pat.
I have 47,000 Kms (25,000 Miles) on the car and am considering either getting it done at the Stealership or doing it my self.
ResQman is offline
Old 05-10-2010, 12:10 PM
Jay-rod427
Jay-rod427's Avatar
BG PRODUCTS 44K if you want to do preventative maintenence on your fuel system.
I have seen it work miracles on cars with SES from misfire due to clogged injectors. About $25 a can and just pour in with fuel.
Jay-rod427 is offline
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
09-10-2015 08:39 PM
Quick Reply: Seafoam Fuel Treatment System
