got to the track last night- numbers are in! pic and vid inside
Old 05-15-2010, 08:11 AM
kugzgt
kugzgt's Avatar
Default got to the track last night- numbers are in! pic and vid inside
go easy on me guys i havent been to the track in about 5 years now, but i can tell you already that i def need some drag radials! i wasnt able to launch w/o spinning like crazy so i was just slipping the clutch here. keep in mind the humidity was ridiculous and the elevation is effin crazy. im not sure if u guys will be able to see my time slip
r/t .472
60' 2.209
1/4 13.773
mph 102.93
scan0007.pdf
http://www.youtube.com/watch?v=JBb8U-zbx2o
kugzgt is offline
Old 05-15-2010, 09:36 AM
teej281
4.6L Section Moderator
teej281's Avatar
Yea, you do need some sticky tires mang. Also, what are you shifting at?
teej281 is offline
Old 05-15-2010, 09:38 AM
gif4445
gif4445's Avatar
Nahhhhhh you didn't spin at all but good times even while spinning
Was that a 99 Cobra next to you? Or a new edge gt?
gif4445 is offline
Old 05-15-2010, 10:09 AM
kugzgt
kugzgt's Avatar
yeah these sumitomos are not cutting it at all. i was shifting around 5900
kugzgt is offline
Old 05-15-2010, 10:14 AM
kugzgt
kugzgt's Avatar
that was a gt. i think he had 3.73s, intake, and exhaust. he wasnt getting lower than 14
kugzgt is offline
Old 05-15-2010, 10:27 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
mrtstang has those same cams and found shifting around 6300 was best. Don't be afraid to rev it that high next time. Even though you have street tires you should spin them before you run just to clean some of the debris off them, it might help.
WannaBeGearHead is offline
Old 05-15-2010, 10:53 AM
Kerns
Kerns's Avatar
What was the DA at the time of your runs?
Kerns is offline
Old 05-15-2010, 10:54 AM
lizzyfan
Underboss
lizzyfan's Avatar
Yea sticky tires will make a world of difference
lizzyfan is offline
Old 05-15-2010, 10:57 AM
lizzyfan
Underboss
lizzyfan's Avatar
If your new and not a fast/flat shifter, best to put your shift light at 6k because by the time you shift you'll have reached 6300
As you get better you can up your shift light RPM indicator
lizzyfan is offline
Old 05-15-2010, 11:22 AM
kugzgt
kugzgt's Avatar
DA???
kugzgt is offline
Quick Reply: got to the track last night- numbers are in! pic and vid inside
