T-Trim Numbers In!!!!! The Good, the Bad, and The Ugly
Old 05-19-2010, 08:04 PM
  #21
0949er
0949er's Avatar
Originally Posted by Kerns
We all know that T-Trims are efficient and powerful blowers, I'm just surprised that you are putting down 450+ on 7-8psi. On 10PSI with your cams I could easily see it. I would just really like to see you take it to the 1/8th and/or race MustangMan00... With 457rwhp you should trap around 93mph in the 1/8th.
how much boost do you run?
0949er is offline
Old 05-19-2010, 08:14 PM
  #22
Kerns
Kerns's Avatar
I run 9psi but don't have cams like you do.
Kerns is offline
Old 05-19-2010, 08:18 PM
  #23
0949er
0949er's Avatar
and I have a bigger blower, so I mean, those combined im sure are worth about 50 rwhp. (and by the looks of it, a lot more...)
0949er is offline
Old 05-19-2010, 08:21 PM
  #24
PurpleIcedGT
PurpleIcedGT's Avatar
oh.my.god
PurpleIcedGT is offline
Old 05-19-2010, 08:24 PM
  #25
Kerns
Kerns's Avatar
T Trim vs V2 S Trim are very similar at low boost. Only under high boost is when T Trims really start to shine vs a V2 S Trim. You run less boost then I do because of the cams. The cams flow better which causes you to see more rwhp and less boost, but shouldn't make you almost 60rwhp higher.
T-Trim
Max Speed: 55000 RPM
Max Boost: 26 PSI
Max Flow: 1200 CFM
Max Power: 825 HP
Peak Efficiency: 73%
V-2 S Trim
Max Speed: 50000 RPM
Max Boost: 20 PSI
Max Flow: 1000 CFM
Max Power: 680 HP
Peak Efficiency: 72%
For the record, I'm not saying your numbers are off or fake or whatever. I am just surprised. Also, at that rwhp your pump should be beyond maxed... most people can take a focus pump to around 400rwhp pushing its limits. Some higher, I have never heard anyone beyond 420rwhp with a focus pump without needing a BAP, and have seen people as low as 370RWHP maxing out the focus pump.
Kerns is offline
Old 05-19-2010, 08:42 PM
  #26
0949er
0949er's Avatar
T-Trim
Max Boost: 26 PSI
Max Flow: 1200 CFM
Max Power: 825 HP
V-2 S Trim
Max Boost: 20 PSI
Max Flow: 1000 CFM
Max Power: 680 HP
I spent 200 on that pump from motorcraft. I am going to say its pretty solid because we specifically asked Dan about that. He showed us the data log of the pump and he said that fuel was not a issue at all.
0949er is offline
Old 05-19-2010, 08:44 PM
  #27
0949er
0949er's Avatar
I will get a dyno sheet up soon as I can get my system switched around so we can finalize my tune. I will get a copy of my previous run (with just cams) and my next run (with the blow-through system) to give exact comparisons for you guys.
0949er is offline
Old 05-19-2010, 08:49 PM
  #28
Kerns
Kerns's Avatar
Originally Posted by 0949er
I spent 200 on that pump from motorcraft. I am going to stay its pretty solid because we specifically asked Dan about that. He showed us the data log of the pump and he said that fuel was not a issue at all.
That is awesome! Glad you aren't having any trouble with fuel. Any chance you will get a race in with MustangMan00 anytime soon? BTW what octane fuel do you run?
Kerns is offline
Old 05-19-2010, 09:30 PM
  #29
PurpleIcedGT
whats next? STICKY TIRES??
Old 05-19-2010, 10:13 PM
  #30
0949er
0949er's Avatar
Haha, prob wont be running MustangMan00 any time soon. He has been my right hand man during this whole process
I run 93 Octane Fuel
going to be looking into 275s in the rear (Some DR, maybe Nitto 555s or something equal)
0949er is offline
Quick Reply: T-Trim Numbers In!!!!! The Good, the Bad, and The Ugly
