Post Info and Pics of Your 99-04 Mustang's Stance
Old 05-22-2010, 05:59 AM
HazMat
HazMat's Avatar
Wink Post Info and Pics of Your 99-04 Mustang's Stance
I'm going to work on my Mustang soon and would like to see what all of your stances look like.
Also a chance for everyone else to see.
Picture:
Front Wheel Size (Height x Width):
Back Wheel Size (Height x Width):
Type of Wheel:
Spacers:
Caster and Camber Plates:
Front Tire Size:
Back Tire Size:
Type of Tire:
Springs:
Amount of Drop:
Shocks and Struts:
Panhard Bar:
Upper Control Arms:
Lower Control Arms:
Anything Else:
HazMat is offline
Old 05-22-2010, 06:49 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Picture: See "As I pass through...." in sig
Front Wheel Size (Height x Width): 18"x10"
Back Wheel Size (Height x Width): 18"x11"
Type of Wheel: Saleen knock-offs widened to above sizes
Spacers: 1/2" in back with longer-stronger aftermarket studs to compensate
Caster and Camber Plates: None
Front Tire Size: 295/30's
Back Tire Size: 315/30's
Type of Tire: Toyo R888's (Summer wheels) Michelin PS2's (Winter wheels)
Springs: 750# SLA CO's (f) 200# CO's (r)
Amount of Drop: about 2"
Shocks and Struts: Koni Yellow
Panhard Bar: Griggs
Upper Control Arms: none
Lower Control Arms: Griggs
Anything Else:[/quote] Don't try this at home!
Jazzer
Jazzer The Cat is offline
Old 05-22-2010, 01:56 PM
HazMat
HazMat's Avatar
Panhard Bar: Griggs
Anything Else:
Jazzer [/QUOTE]
Very Nice
Does the Panhard Bar replace the upper control arms or does it eliminate the need for them?
HazMat is offline
Old 05-22-2010, 02:07 PM
HazMat
HazMat's Avatar
Eliminates the need if you use a panhard bar with a torque arm?
HazMat is offline
Old 05-23-2010, 09:27 AM
jmac72187
corner carver
jmac72187's Avatar
Torque arm will eliminate the UCA's. A panhard bar alone only centers the rear axle.
jmac72187 is offline
Old 05-23-2010, 10:46 AM
avlon06
avlon06's Avatar
jazzer, how are you running around with no c/c plates?
avlon06 is offline
Old 05-23-2010, 07:12 PM
Jazzer The Cat
Retired Moderator
The TA only stops axle wind, while the PHB only stops lateral travel. The UCA's do both, but in a VERY lousy way
Jazzer
PS. avlon..... I do it with magic
... actually, I run an SLA front suspension, so I have completely eliminated my need for strut towers altogether
Old 05-24-2010, 12:55 AM
Kerns
Kerns's Avatar
Picture:In sig
Front Wheel Size (Height x Width): 17x9
Back Wheel Size (Height x Width): 18x9
Type of Wheel: FR500
Spacers: None
Caster and Camber Plates: Maximum Motorsports 4 bolt CC Plates
Front Tire Size: 245/45/17
Back Tire Size: 275/35/18
Type of Tire: Firehawk Wide Oval in front, Dunlap DZ101 in back
Springs: Stock springs in rear, UPR Coil Overs 14/175lb springs up front
Amount of Drop: ~ 2 1/2 inches
Shocks and Struts: Lakewood 70/30 Struts, Stock Shocks
Panhard Bar: None
Upper Control Arms: Stock
Lower Control Arms: Maximum Motorsports Extreme Duty Lower Control Arms
Anything Else:
Kerns is offline
Old 05-24-2010, 01:31 AM
stangit9090
stangit9090's Avatar
lower than *** down, kerns.
stangit9090 is offline
Old 05-24-2010, 02:10 AM
Kerns
Kerns's Avatar
LOL I am going to. Switching to Lakewood 50/50 shocks and will cut the springs 3/4 of a coil when I do.
Kerns is offline
Quick Reply: Post Info and Pics of Your 99-04 Mustang's Stance
