what kind of Cams
Old 06-01-2010, 10:41 PM
xJaredx
xJaredx's Avatar
Default what kind of Cams
I am wanting to buy some cams for my stang and have no idea which kind to go with....i need recomendations pls!! thanks!
xJaredx is offline
Old 06-02-2010, 03:04 AM
mrtstang
mrtstang's Avatar
Check out Modular Head Shop's cams. I recently went with their stage 2's. The owner really knows his stuff when it comes to heads and cams for the mod motor.
mrtstang is offline
Old 06-02-2010, 08:59 AM
JamesDean
JamesDean's Avatar
Don't exceed .500 valve lift or you will run into piston valve clearance issues. Unless of course you plane on replacing the pistons too. I would also recommend getting heads as well. If you would like I can give you the specs on my camshaft and heads, they got me about 70hp with a dyno tune. I went from 260hp to 325hp. Remember both numbers are rated at the wheels.
JamesDean is offline
Old 06-02-2010, 10:44 AM
kugzgt
kugzgt's Avatar
mhs ftw
kugzgt is offline
Old 06-02-2010, 10:56 AM
mustangmancp
mustangmancp's Avatar
I picked up 30 hp from my hitech stage 2s. Make sure you get any cam degreed to make sure you have enough clearance.
mustangmancp is offline
Old 06-02-2010, 11:26 AM
MustangMan00
MustangMan00's Avatar
Cushman MotorSports
MustangMan00 is offline
Old 06-02-2010, 12:12 PM
lizzyfan
Underboss
lizzyfan's Avatar
Originally Posted by kugzgt
mhs ftw
Without a doubt!
lizzyfan is offline
Old 06-02-2010, 02:24 PM
darkstarnes
darkstarnes's Avatar
before any recomendations what are your plans?? want to S/C, T/C, nitrous or just N/A? daily driver, weekend car, or race car?? remember cams are one of the last mods you have to do.... so you can get the best specs for your set up.
darkstarnes is offline
Old 06-02-2010, 02:31 PM
tbirdscwd
tbirdscwd's Avatar
Call Tim at Mr. Norms garage and pick up a set of MPH custom grinds. You won't be sorry.
tbirdscwd is offline
Old 06-02-2010, 03:16 PM
mrtstang
mrtstang's Avatar
Actually the lift has nothing to do with ptv clearance. It's the duration and lsa. With that said he can also run up to a 550 lift just fine with the PI motor.
mrtstang is offline
Quick Reply: what kind of Cams
