Everyone with a vortech/procharger/whatever get in here..
Old 08-03-2010, 09:51 PM
Harryman2002
Harryman2002's Avatar
Took 1 guy to install mine about two solid days of work to get it done, and he only charged me $500! Ive got a boost, wideband and fuel pressure gauge but the wideband isn't on yet.
Harryman2002 is offline
Old 08-03-2010, 09:57 PM
0949er
0949er's Avatar
yeah dont forget for wideband you gotta actually install a o2 sensor into you header as well.
0949er is offline
Old 08-03-2010, 10:14 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Boost and Gas Pressure can tell me exactly what you guys are looking for, less accurately of course. I know if there's 11PSI of boost, I should be around 45-60PSI of fuel pressure. It's good enough for anything that will go on during street driving.
When I was racing, I used the racepak, which was the best guageset I could ever recomend, at which point I had everything, from boost/fuel/oil/wideband/waterTemp/oilTemp. Everything. So yeah, for racing, you need more, for driving on the street where you might run someone from a stoplight every once and a while, or just driving around and hitting the strip every once and a while, boost and fuel pressure are more than adequate.
2000AZ5.0GT is offline
Old 08-03-2010, 10:29 PM
Rockwell28
Rockwell28's Avatar
200AZ.5GT so you would recommend getting a boost and fuel gauge rather than a boost and air fuel pressure if your just gonna play on the streets a bit and hit the track about twice a month at the most? bc i see the widebands are pricey compared to a fuel pressure gauge but i heard the wideband is more of a tuning tool just kinda stuck in between the two wideband or fuel pressure gauge
Rockwell28 is offline
Old 08-04-2010, 06:23 AM
boduke0220
boduke0220's Avatar
How do you put the sensor in there? drill a hole?
boduke0220 is offline
Old 08-04-2010, 07:52 AM
2kStangGT08
2kStangGT08's Avatar
Boost gauge and fuel pressure gauge.
2kStangGT08 is offline
Old 08-04-2010, 12:30 PM
boduke0220
boduke0220's Avatar
Originally Posted by bigmike0405
............ Mustangforums FTW
if you dont like my thread, dont click on it. Pretty simple.
Old 08-04-2010, 02:41 PM
0949er
0949er's Avatar
U gotta drill and thread a spot for the o2 sensor. It might possibly come with a flange that you just weld on. (that is pre-threaded)
0949er is offline
Old 08-04-2010, 02:54 PM
lizzyfan
Underboss
lizzyfan's Avatar
Just a boost gauge
lizzyfan is offline
Old 08-04-2010, 02:57 PM
Mustang3GT07
Mustang3GT07's Avatar
I have an AEM Wideband A/F and then the Autometer boost/vac gauge.
Mustang3GT07 is offline
Quick Reply: Everyone with a vortech/procharger/whatever get in here..
